Whats going on?
Old Dec 30, 2007 | 11:16 PM
bmxbikes's Avatar
bmxbikes is an unknown quantity at this point
Default Whats going on?
Ok so about a week ago my parents bought me a 99 Blazer ZR2. I was driving today and noticed the DRL werent on and only came on when I turned the ****. Then I kept driving and the speedometer stopped working and just died. Then all of a sudden it was hardly moving. I noticed I was low on gas so I filled up and the problem persisted. It shifts barely, makes bad noises, speedometer doesnt work, and it just is sucking. Any idea what it could be?
Old Dec 30, 2007 | 11:23 PM
Blazin_Jason's Avatar
Default RE: Whats going on?
Uh oh you just don't have the best of luck with vehicles. So besides what you mentioned, does it still drive around? Start with checking the tranny fluid. What type of noises are you talking about?
Old Dec 30, 2007 | 11:24 PM
bmxbikes's Avatar
Yea my luck blows. And yes it still drives just not well and im afraid to keep driving it. It will rev to about 4500RPM before it shifts and when it does its not smooth at all. And when I stop and hit the gas you hear a clunk like metal hitting metal.
Old Dec 30, 2007 | 11:25 PM
Chevy Lover's Avatar
I haven't got a clue.....how's the charge in the battery?
Old Dec 30, 2007 | 11:26 PM
bmxbikes's Avatar
Battery reads 14v.
Old Dec 30, 2007 | 11:33 PM
What about in park or neutral, does it idle rev ok? Hopefully it isn't a trans problem. Did you get any warranty with it?
Old Dec 30, 2007 | 11:42 PM
WolfPack's Avatar
one of my old cars used to do that. it had a tranny leak and started doing that when fluid was essentially gone.
if your blazer has a slow leak or weeping seal, over time from it sitting on a lot, it's understandable for there to be really low trans fluid
Old Dec 31, 2007 | 12:15 AM
bmxbikes's Avatar
There is a warranty but looking around it could be the speed sensor. Searched around and found alot of the same problems being caused by this. Now the DRL i dunno whats wrong with those.
Old Dec 31, 2007 | 05:37 AM
It's possible that a previous owner disabled the DRLs... Run a search on how to do that and you should be able to reverse it.
Old Jan 1, 2008 | 10:38 PM
4x4willywill's Avatar
4x4willywill is an unknown quantity at this point
ORIGINAL: bmxbikes
this sounds like the driveshaft u-joint is broken, i would get underneath and turn it by hand and see if anything is bent or broken at the front of diff ujoint and yoke ujoint .
rexazz2
Jun 3, 2013 10:56 PM
cochran07
Jan 23, 2011 01:21 PM
wardlarson
Oct 11, 2010 11:12 PM
Bad4Point3
Sep 12, 2008 08:29 PM
bmxbikes
Dec 30, 2007 11:31 PM
