Whats the proper way to engage your 4wd without making grinding noises?
Old Dec 10, 2012 | 07:20 PM
The inner axle shaft and the clutch shaft have teeth and they are connected by a sliding sleeve when you select 4WD. If the teeth are not perfectly aligned, the sleeve will not slide. The two shafts do not rotate at the exact same speed, but close, so moving the vehicle at any speed will align the teeth so the sleeve can engage the two shafts together.
Old Jan 1, 2014 | 03:53 AM
joshn444's Avatar
joshn444 is on a distinguished road
Default Need advice
Ok guys I have the 4 button 4x4 and lately almost every other time I try to engage it it grinds but, it always changes over and gets me out of whatever I'm in. Is there a way I could stop this grinding all together? Posi lock mod? Even auto4wd grinds in the switch. Usually I'm giving it a little gas but far from the floor and I used to be able to do this without any grinding but this winter season it's been grinding I'm worried about the longevity of my transfercase and 4wd parts. Any suggestions?
I don't mean to thread jack but I've been having trouble getting replies to any threads I start lately
Old Jan 1, 2014 | 07:07 AM
hubert hefner's Avatar
hubert hefner is on a distinguished road
Does it grind on a snow covered road or just when you put it in 4wd on a dry surface? Are all of your tires matching?
Old Jan 1, 2014 | 05:11 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
my 96 blazer without electric shift says to put it in park to go from 4hi to 4lo.
read your owners manual for proper operation. if you don't have 1 a quick google search and you'll find 1
Old Jan 1, 2014 | 06:33 PM
joshn444's Avatar
I only engage 4wd in the snow or off-road never on dry pavement so to answer your question yes it grinds on the snow but I don't know about dry pavement, and three of my tires match the other is the spare it's on the front drive side
Old Jan 1, 2014 | 06:55 PM
If there is any height difference in your tires it can have an effect on it but that usually makes a "pop" sound not an actual grind. Even if one is slightly different that shouldn't effect it on a snowy or off road terrain. How's the oil in your t-case? Have you ever noticed any metal shavings in it?
Old Jan 2, 2014 | 01:19 AM
joshn444's Avatar
Tcase oil.... Never looked at it and my dad and I have had the blaze since new....
Old Jan 2, 2014 | 06:04 PM
The NV236, (Auto 4 button), has a clutch pack and needs regular fluid changes every 50K miles, maximum. Fluid change takes just under 2 quarts. Gotta use this stuff, available at any GM dealer:
Old Jan 3, 2014 | 12:23 PM
abig84's Avatar
the way i always do it, same as disengaging it, is put it in neutral pull the lever or push the button. wait a second, back up about 2 feet then go forward.
Old Jan 8, 2014 | 05:41 AM
TD44's Avatar
TD44 is on a distinguished road
for sure the best way to engage,last thing your drivetrain needs is more stress
Alex_Alex
Sep 22, 2012 12:01 AM
pirkeltooned
Jun 10, 2010 11:11 PM
bigdaddykane93
Jan 23, 2010 02:10 PM
BLK85
Jun 7, 2007 01:37 PM
2001blazer
Mar 29, 2006 01:51 AM
