Wheel Alignment Specs for 2000 4WD Blazer
Old Jun 9, 2009 | 06:20 AM
ronkrolock's Avatar
ronkrolock is an unknown quantity at this point
Default Wheel Alignment Specs for 2000 4WD Blazer
Hello. I have a right-hand-drive year 2000 Blazer (4WD) that is starting to wear the outer edge of the front tyres. Can anyone tell me the front wheel alignment specs (i.e. the amount of toe-in) for this truck, as the workshops over here in the UK don't keep information about Blazers. I could get them to set the wheels parallel, but I'd prefer to know the proper settings. Had a look on the forums and on the net, and can't find them. Does anyone know? Many thanks. Lee
Old Jun 9, 2009 | 05:13 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Caster: Allowable 2 to 4 Preferred 3
Camber: Allowable -1 to 1 Preferred 0
Toe (total) Allowable -0.10 to 0.10 Preferred 0.1
Old Jun 9, 2009 | 07:53 PM
Spot on.
Old Jun 10, 2009 | 05:41 AM
ronkrolock's Avatar
Default Unit check
Many thanks guys. Can I check, though, what units are you using? When you say -0.1 to 0.1, do you mean mm, inches, degrees..? Many thanks. Lee
Old Jun 10, 2009 | 08:59 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
These should be in degrees. Although depending on the alignment machine it may be in inches. The toe in is measured in inches. Although if I'm wrong someone please correct me.
Old Jun 10, 2009 | 11:13 AM
RonJon's Avatar
Degrees or fractions thereof. I think toe is 1/8" if you convert it to inches, but GM gives the info in degrees.
I added the Caster & Camber specs so he could check them and if he needs to adjust anything: In this order; adjust the caster, adjust the camber, adjust the toe.
Old Jun 11, 2009 | 06:17 AM
ronkrolock's Avatar
Default Thanks
Many thanks guys - I appreciate your help. I'm sure the shop will be able to work it out from this. Lee.
blazen_red_4x4
Oct 13, 2014 12:39 PM
BRoss99
Tires and Wheels
Aug 30, 2014 04:05 AM
Steinbruchsoldat
Jun 20, 2010 05:56 AM
chop
Feb 20, 2010 05:44 AM
Walleye
Suspension Tech
Feb 26, 2006 10:35 PM
