wheel center caps for 2004 4wd ?
Old May 5, 2019 | 11:00 AM
blackhawk61's Avatar
blackhawk61 is on a distinguished road
Default wheel center caps for 2004 4wd ?
Will 2004 up Malibu or Impala caps work ?
Old May 5, 2019 | 01:04 PM
I know they won't work on ZQ8 wheels... I tried. Even though they looked the same, and were very close in size, the didn't snap in and hold...
Old May 5, 2019 | 01:13 PM
Trukntigger's Avatar
The caps really depend on which rim you have. They were not all the same. If your talking ones that look like this-
Note mismatched center caps.
These are on my 98. Ended up using these as replacement for all 4 and put center covers on them.
Center caps for 59mm opening. These fit the above rim perfect with no trimming or filing.
The outer ring is 65m and several cap covers are available for them. I used these-
Covers for 65mm cap
Which gives this look-
Above product mounted in use. Added a extra piece of 3m double sided sticky tape to center under cover for extra holding power.
I do not know the other types but just that I have seen several based upon rim style.
Old May 5, 2019 | 02:54 PM
Default this wheel
Old May 8, 2019 | 01:15 PM
N. Jensen's Avatar
Try the Malibu/Impala caps out in the salvage yard.
If they don't work, here's a set;
https://www.ebay.com/itm/1998-2005-C...AAAOSwKZZcwl51
jpjones55
Sep 28, 2015 03:53 PM
05BlackJimmy
Tires and Wheels
Dec 2, 2012 07:18 PM
chvyblazer00
Mar 27, 2011 10:21 PM
