Wheel Speed Sensor Location
I've scoured the internet and books trying to find something specific about where the wheel speed sensor is located on my '02 Blazer 4WD. Does anyone know specifically!?
Are you talking about the tone ring that senses wheel speed for ABS brakes, or where vehicle speed is calculated from?
The ABS Sensor, I think the one in my driver front wheel is going bad, my light turns on when I turn Left (change in tire speed [faster] compared to others) and I'm getting a quit moaning noise, like the ABS are trying to slow that wheel down. I think it is faulty and engaging the ABS because it thinks I'm skidding... at least thats what my thought path is
if that one wheel is "moaning" you need to replace the wheel bearing unit. its a sealed unit and easy to replace.
The new wheel bearing (or hub assembly as it's called) needs to be replaced as lee said if you're getting a wailing sound. The good news is the hub assemblies come with new wheel speed sensors, so you get to kill two birds with one stone. They're anywhere from $80-$150 depending what one you get. I've heard good things about Timken hubs, and of course if you're willing to pay AC Delco is always a good choice.
You can try just replacing the WSS, but it's around $60 on it's own, so you're better off forking out the few extra bucks and getting the whole hub assembly.
Got a new hub today... went to take everything apart, when I went to remove my brake caliper mounting bracket the lower bolt is corroded so bad that the head rounded and now I can't get a grip on it. AWESOME! I poured a bottle of WD-40 on it, heated it, pry bars and got a smaller socket on it, and it still won't move... I'm about to the point that tomo I'm going to go after the bolt head with a hack saw and cut the shoulder and head off in hopes that I will be able to just pull the bracket off, and just get a new bracket... unless anyone can come up with a away to get that bolt out... The bolt is lost and there is no way I'd be able to get it tight to the torque requirement, so if anyone has any idea on how to at least get it out and save the frame, I'm all ears.
Hot wrench, real ViseGrips, and a lot of elbow grease.
How did you make out getting the bolt out. Also I don't know why know one told you this but If you hear the moaning noise when turning left it's the right side hub bearing that's bad and if you hear it when turning right it's the left side hub bearing that's bad.
Pipewrench Dale
11-10-2014 06:16 PM
