Where can I order this part?
Old Dec 8, 2006 | 10:32 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Where can I order this part?
All of my a-arms on my blazer are getting real rusty, and the rubber bushings/seals/guards that keep the a-arm from rubbing against the metal mount (frame). Well those rubber rings are really old and are craking real bad so I would like to change all of them. But where do I buy these?
Old Dec 8, 2006 | 10:54 PM
hillbillyinOhio's Avatar
Default RE: Where can I order this part?
you talking about bushings?? you can get a whole bushing set from summit racing for reasonable price.
Old Dec 8, 2006 | 10:57 PM
Will this take care of one whole side...I should have taken a picture when I had the wheel off. All of the rubber bushings are cracked but if I am changing the bushing I mid as well change the ball joints on the outer arm while I have it apart...
Old Dec 8, 2006 | 11:01 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
A-Frame bushings... Advanced Auto Parts, NAPA, Pep Boys whatever is in your area.... They're not really a dealer only item. The WORK of replacing them....? That's a bit of a job, they're a press fit, a steel "tube" that fits into the A-frame with the rubber bushing in it. If they clunk, have slop or play, yes by all means they need replacing. But just for squeaking I think I'd start with grabbing the 'ol WD-40 or PB Blaster and spray 'em, drive it a bit, spray a bit more until/if the noise gets better. Anyone know of a good spray that's supposed to be rubber bushing friendly? On mine I'd be willing to swear it's the rear leaf springs that make the squeak, but it's not often or annoying enough I've taken the trouble to look...
Old Dec 8, 2006 | 11:05 PM
Squeaking isnt the problem at all, its just the rubber is craking like crazy lol...I dont need to replace them but it would be nice to keep up on parts wearing out...
Old Dec 8, 2006 | 11:21 PM
RonJon's Avatar
<laughing> I guessed at craking = creaking instead of cracking yeah they do get all cracked looking. I've replaced them on a few cars but only because they were clunking and I could see the rubber was worn and sloppy and starting to fall apart inside of 'em. The cracking on the big outside ring is more of a cosmetic thing. But if you have to do a ball joint and things are already apart that is a good opportunity to do 'em..
Old Dec 9, 2006 | 12:03 AM
magnum434's Avatar
magnum434 is an unknown quantity at this point
LMC Truck
spider21
Nov 17, 2011 06:27 PM
southernsteel87
Oct 15, 2010 09:50 PM
USMaverick101
Oct 20, 2006 06:46 PM
tesshin
Sep 11, 2006 10:05 PM
Rahmir
Aug 16, 2005 12:52 PM
