where do i find my vacuum tank in my fender
Old Dec 28, 2012 | 07:01 AM
turple27's Avatar
turple27 is on a distinguished road
Default where do i find my vacuum tank in my fender
i am just wondering where i can find my vacuum tank in my fender, i noticed my front diff wasnt engaging so i looked towards the vacuum system and i found that my vacuum line to my vacuum tank wasnt connected to it and i cant seem to figure out how to find it, can anyone help me
Old Dec 28, 2012 | 07:29 AM
LannyL81's Avatar
The vacuum tank inside the left front fender is a bit difficult to locate. All the comes through is the tiny hose nipple. It it between the firewall and the brake ABS module. A good light and feel will find it.
Do NOT take the inner fender liner loose hoping to find the tank....you will not...trust me..I found this out the hard way.
Old Dec 28, 2012 | 07:38 AM
AintQik's Avatar
AintQik is on a distinguished road
Mine worked without that line hooked up. A better way to troubleshoot would be to pull the battery tray and see if the cable is moving. That will tell you if its vaccuum or other.
Old Dec 28, 2012 | 03:00 PM
turple27's Avatar
well i was still able to use my 4wd i plugged the line with a screw so it can build its vacuum, i just need to find my tank to reconnect it
Old Dec 28, 2012 | 03:14 PM
The reservoir nipple is between the cruise control module and the ABS unit. The nipple is horizontal and points toward the engine. The reservoir is flush with the body panel and the nipple only sticks out about 3/4".
Attached Thumbnails where do i find my vacuum tank in my fender-vacuumlines.jpg
Old Dec 28, 2012 | 05:22 PM
rockp2's Avatar
I ran into the same issue...at the end of this link I described what I did to get to that nipple. It's actually a fairly quick job to do..about 10 or 15 minutes. https://blazerforum.com/forum/engine...nowhere-75282/
Old Dec 28, 2012 | 06:34 PM
aa21830's Avatar
aa21830 is on a distinguished road
Here is what it would look like with a bunch of stuff moved out of the way:
Attached Thumbnails where do i find my vacuum tank in my fender-vacuumcannisterinfenderwall-744x560.jpg
Toby Hanson
Jul 7, 2014 08:21 AM
Smc
Nov 14, 2013 04:46 PM
crater
Mar 20, 2013 11:23 PM
wjdjake
Jul 17, 2011 02:06 AM
Old Man 2
Dec 4, 2010 02:55 PM
