Where does this line go.
Old Sep 30, 2019 | 01:52 PM
Mltoys's Avatar
Mltoys is on a distinguished road
Default Where does this line go.
Suddenly I hears hissing by left fender, found this hose laying in between the 2 black things.
Old Sep 30, 2019 | 01:56 PM
Theres a reservoir inside the drivers fender right about where the abs unit is.
Old Sep 30, 2019 | 02:40 PM
Mltoys's Avatar
Thank you,
Guess I cant just stick my hand in there ?
Old Sep 30, 2019 | 04:31 PM
Not too sure, someone else will chime in soon that has, I just plugged it. Haven't had a problem yet... been a few months if not a year...
Old Sep 30, 2019 | 07:42 PM
Originally Posted by Mltoys
Thank you,
You can probably see it if you look down there with a flashlight.
Old Sep 30, 2019 | 08:20 PM
Mltoys's Avatar
did that to drive tonight, burned half the gas as usual. Coincidence ?.
thanks, will try it
Old Sep 30, 2019 | 09:08 PM
An inspection mirror helps to show where it goes. If the hose is in good shape, you can make sure it doesn't come off again by using a zip-tie as a mini-hose clamp. However, if the vacuum hoses are original, they can be deteriorating and be losing their elasticity. The later could be why the hose came off.
I made a thread on replacing the hoses on my 1999 that has a 4-button controlled transfer case. the Thread is in my signature below.
Old Oct 1, 2019 | 07:12 AM
Mltoys's Avatar
Thank you Christine,
so it goes to the reservoir. Whats the purpose of reservoir ?
Old Oct 1, 2019 | 09:57 AM
The reservoir supplies vacuum when the engine is under load and the pressure in the intake manifold rises up to close to atmospheric pressure, i.e. when it has "less vacuum". That is the purpose of the one-way valve that is inside the Tee connector to which this hose is connected. It looks like your hoses, or at least a few of them have been replaced but that this hose came off indicates that it might have aged enough to loose its elasticity and either should be replaced or as I suggested additionally secured with a zip-tie as a hose clamp.
The vacuum is used in several places on our Blazers. First it is used to supply vacuum to the actuators that direct to where the air goes in our HVAC systems. Second it is used for controlling parts of the 4wd system. On 3-button transfer case models, it it used to engage the front axle and to direct the transfer-case to switch into 4wd mode. On the 4-button transfer case systems (the ones with the additional Auto 4wd) the vacuum for the 4wd system is only used for the front axle engagement with the transfer case controlled electronically.
Old Oct 5, 2019 | 06:17 AM
Mltoys's Avatar
Thank you again Christine
HostileJava
17
Feb 2, 2024 02:29 PM
zr2dan
14
Jan 3, 2012 06:25 PM
trishharris
Dec 2, 2011 04:23 PM
sunnyblueskies
Sep 12, 2011 01:07 PM
Gkolo
Oct 28, 2010 02:40 PM
