Whining on acceleration
Because the whining matched the gears shifting I assumed I had a transmission problem nut a real mechanic said I needed a new belt, pulley and tensioner.
https://photos.app.goo.gl/j3oKC3gk8at8cW5Q6
https://photos.app.goo.gl/Rfs63WoLpaU8pfjs9
Maybe this video will work https://youtu.be/XUMKanPwVz4Looks like the tensioner is shaking but idk if that is unusual enough to cause the whining. Shop wanted $592 to replace..
Use a ratchet to release the tension on the tensioner (with the engine NOT running) and turn the tensioner pully by hand to feel for roughness. If it needs to be replaced, it's like a $25 part, and 15 minutes of work to replace it (if you stop halfway through for a beer break).
Is it low on power steering fluid? .... or did you just add some kind of generic fluid to the power steering system. .... or is the power steering pump bad? This can cause a whine that goes up and down with engine speed, but especially when you turn the steering and hold it against it's right or left lock.
steering and transmission fluids are good and all behaving normally. except the whining. I ordered the parts and will give self-installing a go when they arrive.
If that doesn't work I might try a transmission fluid drain & filter
I replaced tensioner, pulley and belt. Still got the whine, but I still still got the $500 the mechanic wanted!
Posts here have indicated whining could be low transmission fluid. Mine is good on the dipstick, maybe the filter is clogged and it's not getting up into the gears?
Autozone check was all "Okay" but backing into the driveway just now the car died - first time that ever happened.. I got it going but the dash lights didn.t come on for a minute. when I listen to it through a dowel the alternator make a good noise, If Im unplug it it still makes a noise.. Temp of the alternator housing after driving was 190. Volts are just a hair under 14, used to be a hair above. Power steering fluid is good and steering works fine. Does a bad alternator whine on acceleration?
Suspect power steering if its a real whine. Post a video with sound showing gauges (rpm). Hold steering tight against one of the locks (right or left) and increase rpm from idle to about 2500. We can eliminate or confirm from that.
