Whining after A/C compressor installed
Old Aug 8, 2010 | 03:04 PM
ashelton96's Avatar
ashelton96 is on a distinguished road
Default Whining after A/C compressor installed
Hello.
I have a 2002 Chevy Blazer LS V6 4.3. I had a new a/c compressor installed after the clutch burned out on my old one (flush,evac, and recharge done also). I just had it done this weekend but since then I've noticed a whining noise when I am accelerating with the a/c on. It only does it until about 35-40 mph and then can't be heard. It occurs when driving straight so I don't think its with my power steering but need to check it anyways. I also had a new altenator and belt installed this weekend too. Does it sound like the compressor or clutch and is this common with a new one? Should I be worried or will it disapate over time? Thanks for your help!
Andrew
Old Aug 8, 2010 | 05:55 PM
If it only happens when the compressor is running, I would suspect a problem with the compressor or with the front drive belt system on the engine. The load could cause a pulley to whine.
Old Aug 8, 2010 | 06:01 PM
ashelton96's Avatar
Thank you. Is this something that could turn serious? Any advice?
Old Aug 10, 2010 | 11:36 AM
ashelton96's Avatar
Ok. To followup I did notice that the whining is occurring when the blazer shifts gears (its an automatic). Is this normal for a new compressor and will it go away? Thanks!
Old Aug 10, 2010 | 05:11 PM
As far as how bad it could get, that really depends on the actual cause of the problem. The compressor shouldn't whine at all.
xs2003
Jun 1, 2011 10:46 AM
cartunez2004
Apr 9, 2011 09:01 PM
gmcjimmy_94
Dec 30, 2010 12:37 AM
vze4yrte
Aug 30, 2010 09:08 PM
4x4willywill
Dec 23, 2007 04:33 PM
