whining noise
Old Jan 17, 2007 | 05:20 PM
99whiteblazer's Avatar
99whiteblazer is an unknown quantity at this point
Default whining noise
Under acceleration i have a whining noise and gets louder the faster i go. It sounds like it's coming from the alternator but not sure do alternators make that kind of noise when there going bad or is a pulley. I can't figure it out and don't want to replace something that's not broke. Any suggestions?
Old Jan 17, 2007 | 06:34 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Default RE: whining noise
My alternator made that same whinning noise for a few days, then died...........
Old Jan 17, 2007 | 06:53 PM
JustBlaze!'s Avatar
JustBlaze! is an unknown quantity at this point
I need a little more info. Is it a high or low pitch whining noise? does it change pitch with speed or when you go through dips in the road? With the truck parked, start it up and pop the hood. Can you hear the whining noise? If so, does it change pitch or volume when you throttle the motor?
Old Jan 17, 2007 | 09:38 PM
The pitch gets higher the more gas you give the truck. When i pop the hood at idle you can't really tell it's there when you hit the gas is where you hear it. As for the pitch i wouldn't really say it very high it kinda sounds like a supercharger whine.
Old Jan 17, 2007 | 09:53 PM
BLK85's Avatar
BLK85 is an unknown quantity at this point
That sounds just like what mine did for about a week, then I replaced the alternator and it solved the problem. I described it exactly the same (supercharger).
Old Jan 17, 2007 | 11:17 PM
Thanks for your help i'll replace it tommarrow and hopefully it will do the trick.
Old Jan 18, 2007 | 05:06 PM
JustBlaze!'s Avatar
I would agree, I sounds like its your alternator thats about to go. Mine did the same thing. Just to double check, take off the sepentine belt (you'll have to do this anyway when you replace the alternator, so might as well practice now) - remember to take a picture or make a drawing if you don't have a diagram in your engine compartment so you can put it back together. Start the motor (without the belt) and listen if the sound is still there; then give it some gas, is the noise still there? If your alternator is the cuprit of the whinning, you should not hear the noise. If the noise is still there then you have something else causing it.
Make sure you only run this test for a minute or 2 then turn off your engine. Taking off your belt disables the water pump and will cause your engine to overheat if you run it for prolonged periods.
Old Jan 18, 2007 | 09:23 PM
Changed the alternator and that fixed the problem. Thanks for your help.
Old Jan 18, 2007 | 10:04 PM
Glad to see you got it fixed!
blazergrl75
Mar 18, 2009 06:44 PM
Sorell
Jan 13, 2008 03:49 PM
chizz42
Dec 8, 2007 07:54 PM
smh7890
Jul 28, 2006 08:46 PM
skinny pimp gator
Jun 20, 2005 02:23 AM
