whining sound from radio
Old Jun 7, 2005 | 12:21 AM
tango1112's Avatar
tango1112 is an unknown quantity at this point
Default whining sound from radio
Well, electrical problems are my least favorite to diagnose and GM vehicles can be loaded with them. I noticed a whining noise that sounded like it was a bad in line noise arrester somewhere in the radio circuit. Not wanting to take apart my interior just yet I ignored it. It would increase and decrease in accordance with my RPM's. Well, I had a problem recently when I went to start the car it would turn over great but would not RUN. Never happened before, it's a 2000 4wd, but it just would not run. So, I had my wife turn over the ignition while I played with the pos. battery wire a little. Cranked right up... So, we drove it around an hour to do some errands and then we get back home, let it cool off a bit and I took the battery out to see if I could locate a fault connection. Well, I traced the positive wires down below the battery tray, then removed the battery tray to access them further, and located a junction box that housed a connection for the battery and 2 red connections coming out the other post on the other side 1 in = 2 out... Well, all I did was take it apart, remove the supply connection and cleaned it a little, no real sign of any corrosion or looseness. I then placed it back and had my wife finish up reinstalling the tray and battery. We did not tighten or loosen anything else in the starting or charging circuit, and I didn't go anywhere NEAR the wires for the radio. However, it started up fine and I noticed today that the whine that was coming from the radio is GONE??? Just curious if anyone has had similar issues and what their resolutions may have been. Also, does anyone have an idea of what we "FIXED"???
Thanks
Old Jun 15, 2005 | 07:11 PM
Hanr3's Avatar
Default RE: whining sound from radio
Sounds like you fixed a loose or corroded connection.
On a side note: AC Delco batteries are natorious for corroding at the positive post. If let go too long I have seen the positive cable fall out and battery acid leaks all over the place. The post breaks off in the battery, the first sign of trouble is hard starts, intermittent electrical problems, etc. Some don't even show signs that it is broken until you try to unscrew the stud.
steven mcnaught
Jan 11, 2011 09:46 PM
bigfish
Jan 16, 2010 05:14 PM
J.C.Vice
Feb 6, 2008 07:55 PM
schnitzer00
Apr 17, 2007 04:54 AM
schnitzer00
Apr 12, 2007 07:53 PM
