Whiny noise coming from under the hood.Could it be the bearing from the tensioner?ll
Old Aug 26, 2010 | 11:14 AM
blacer2000's Avatar
blacer2000 is on a distinguished road
Default Whiny noise coming from under the hood.Could it be the bearing from the tensioner?ll
Lately i have been noticing that for the first few minutes after I start the car i hear a noise like from a bearing. Could this be from the belt tensioner? what are some things to check?
Noise is still there with ac off.the frquency also increases as you accelerate and even with the car on park it makes the noise. after a while it will go away but it has been getting worse and lasting longer than before. thanks for the help guys.
Old Aug 26, 2010 | 01:22 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
it could be any number of things, can you post a video to youtube of the sound and give us the link? another way would be to pull the belt off and spin each pulley by hand and see which one makes the noise
Old Aug 26, 2010 | 09:04 PM
blacer2000's Avatar
I will try to take a video this weekend since now I dont have much time now. But I took the pulley really quick by hand and spun each of the pulleys and it is difficult to say. They all make a little of noise almost like a bearing needing grease. The belt tensioner pulley did not feel very good at all though. It made noise but it also felt bad when I spun it. Could this be the most likely culprit it?
Old Aug 27, 2010 | 07:20 AM
each pulley should spin freely with no noise, if you suspect the tensioner pulley then spray the bearing down with the belt off and then put the belt on and start the truck, if the noise goes away then you have a tensioner pulley that's bad. did you try to tilt the top of the pulley in and out in addition to just spinning it? their should be no play in the pulley from tilting the top in and out
Old Aug 27, 2010 | 08:29 AM
blacer2000's Avatar
I did not try to move the pullyey sideways but i will try that again. if i spray the bearing and the noise goes away then i should replace the bearing or with the oil i am all set?also, can i do the same procedure to the other pulleys without harming anything?thanks for the help
Old Aug 27, 2010 | 09:28 AM
spraying lube on the bearings is just a temporary fix, if you dertimine which pulley it is ( tensioner or idler ) then you will have to replace the whole pulley, the bearing is part of the pulley. dont spray lube on the alternator though!
Old Aug 29, 2010 | 05:00 PM
blacer2000's Avatar
Well I took the belt off with more time now and it's definitely the alternator pulley. It squeaks when I spin it. My alternator works great and I never have any problems with the battery even though I have aftermarket stereo with a sub. It would suck to change this just because a squeak. Any ideas or should I just let it be until it gets real bad, then change it?
cjw4050
Mar 23, 2014 10:07 AM
Radar0066
May 28, 2011 12:11 AM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
Hodad
Jun 7, 2009 04:30 PM
Shaftjohnny88
Jun 4, 2005 07:58 PM
