Why did my transmission get soft?
I changed thetransmission pan gasket and filter on my 2000 4wd Blazer
and 4 quarts of trans oil. After I did so, the truck would not move in either Reverse or Drive for about 10 minutes. Finally the trans started to engage and I was able to drive it but it has hardly any power. Trans
seems soft. I got to hold gas pedal down longer to achieve same power.
I used Autozone ATF fluid. It says on it for Ford and Gm. That was the only one available.
Whats wrong and how can I correct it?
When I changed the tranny fluid in my first gen (fluid in the pan and the filter) it took about 5 quarts, I started out with 5, went through all the gears, checked it and added as needed.
Also, you didnt pinch any wires between the pan and the tranny when putting the pan back on did you?
Im not exactly sure how much it should hold but if you have to little in there then it wont want to go into gear but if you have to much in it will be sluggish.
Did some searching up, the 4L60E takes about 5-6 quarts like I thought, so start with adding another one, check the level and drive it around, see if it fixes the problem.
4L60E uses DexronIII fluid. Better check the label on the Autozone container.
You bought what equals the old Dexron III standard. 5-6 quarts are needed as noted but the dip stick will tell the tale on where the level is low, just right or high.
We have automatics from 1992 though 2003 and now we do the bucket flushes using WM Dexron VI ATF only.
What is the proper way to check fluid level on 2000 Blazer.
On a Honda I had the engine had to be off.
Check it hot idling on a level surface in, park or neutral. fluid should be around 180 degrees to check on the hot level
I got the same problem, except the truck goes into gear fine, but drives funny. Was your fluid black when you changed it? If so, you might have a bigger problem. Did you replace the seal on the trans filter? If so, the filter might not be fitting in properly and the pump is sucking air and not allowing it to engage. With it only locking in after a few minutes, that seal could be swelling when it warms up, allowing it to work. Also, check your electrical connections at the PCM and the trans.
4L60E uses DEXRON III from the factory and GM recommends using DEXRON VI as of 2007. I have never seen DEXRON II in any store, so they probably don't make it anymore or at least don't sell it in the stores. Multivehicle ATF that says GM (like with MAXLIFE, it says DEX/MERC), is usually for GM transmissions that use DEXRON III. GM licenses DEXRON VI and won't let anyone say their fluid is compatible with DEXRON VI unless it is licensed. MAXLIFE is compatible with DEX VI, but they are required to refrain from stating it on the front of the bottle as DEXRON VI because it isn't licensed. Valvoline says you can use it for DEXRON VI, but GM would void the warranty because it isn't a licensed DEXRON VI fluid.
I just changed the fluid (I didn't drop the pan. I have a drain plug and a deep pan. Filter was changed last year.) with Valvoline MAXLIFE as usual (the bottle says it complies with DEXRON VI specs as well as DEXRON III) and now not only is the truck slow to accelerate, but it shifts weird and late. I am pretty sure the fluid is overfilled, but wouldn't it just come out the overflow? This trans runs pretty cool since it has a transmission cooler. I could touch the bottom of it and unless I was just on hills, it is only warm, not hot.
