Why is my eater core is leaking
Old Sep 25, 2008 | 04:20 PM
freakgt's Avatar
freakgt is an unknown quantity at this point
Default Why is my eater core is leaking
1997 blazer 4x4-I never got really good heat in the winter so todayI figuredI would try flushing out my heater core. And now afterI flushed it out its all of a sudden leaking in the truck. It never leaked before, so why is it leaking right afterI flushed it out?
Old Sep 25, 2008 | 05:33 PM
Default RE: Why is my eater core is leaking
The most likely cause is that there was a blockage in the core which resulted in corrosion. The blockage was sealing the corroded heater core. When you flushed the core, you removed the blockage and now have a leak. Happens more than you would think.
Old Sep 25, 2008 | 08:43 PM
freakgt's Avatar
Never mind it stopped now.wasent dripping coolant,was only dripping the waterI flushed it out with I'm guessing. I still dont understand why it would drip water all of a sudden then stop. Thanks for the help though!
Old Sep 27, 2008 | 04:42 PM
blzR's Avatar
blzR is an unknown quantity at this point
Sounds like you optminism will be short lived.Betting the hole just got blocked again.
franklin
Feb 28, 2012 01:42 AM
blazinloud
Jan 5, 2011 10:29 AM
1994BlazerS10
19
Nov 21, 2009 02:06 AM
ShadowHawk
23
Nov 12, 2008 01:50 PM
Canadian_Blazer
Mar 17, 2005 12:18 PM
