wierd noise from front end!
Old Jul 9, 2008 | 03:55 PM
s10 2.2much's Avatar
s10 2.2much is an unknown quantity at this point
Default wierd noise from front end!
hey everyone new to the site ....i have a 97 gmc jimmy 4x4 while im driving down the road it has a dull humm ...like a wheel bearing starting to go ....i replaced both front wheel bearing with no luck ...if i push the 4x4 it goes quiet the front drive shaft seems tight and the front diff is full of oil any one have any similer problems ? thanks in advance
Old Jul 9, 2008 | 06:28 PM
Default RE: wierd noise from front end!
Could be that the front axle actuator is not fully disengaging. This could be due to a failed return spring at the actuator or a cable that is stiff.
Old Jul 12, 2008 | 01:37 PM
i will have to look into the spring ..is it behind the little black cover on the pot? mine is push button 4x4 will it still have a cable ?
Old Jul 13, 2008 | 11:03 PM
mrock's Avatar
mrock is an unknown quantity at this point
I have had the same problem. It may be do to the 4-wheel drive system. On mine you could feel it engaging and disengaging, but most of the time the 4-wheel drive dosen't work. Let me know what it's ends up being cause I haven't gotten mine fixed yet.
TennesseeBoy
Apr 5, 2014 07:49 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
Chrismacster
Apr 2, 2009 06:57 PM
tbrinker
Jul 16, 2006 10:02 PM
DanishDonut2
Sep 9, 2004 05:17 AM
