will it pass somg
Old Apr 16, 2012 | 01:23 AM
akblazer2000's Avatar
akblazer2000 is on a distinguished road
Default will it pass somg
I have a 2000 blazer 4x4
I have been trying to fix a P1035 for a long time with no luck however the light is off on the dash but the code is still in there, ALL MIL have passed and say ok or n/a.
My smog is due soon what are my odds of it passing in this condition?
Thanks,
Alex
Old Apr 16, 2012 | 08:13 PM
abig84's Avatar
if you just cleared the code yourself they will know. the vehicle will have to go through its drive cycle to clear all the emissions codes. even at work if we replaces something emissions related half the time you cant just fix it and clear the code and they can go get it tested, they have to drive it for a day or so to reset the light itself.
you can try, out here we get like 3 tries before you have a issue
Old Apr 16, 2012 | 08:26 PM
I have not cleared the code it in along time and all the drive cycles have passed.
motorcity blazer's Avatar
motorcity blazer is on a distinguished road
Do you mean p0135? If so that pertains to an o2 sensor problem I believe. Anyway I don't know which state you are in but phoenix Az has pretty tough emissions standards (where I live) and as long as the SES light is NOT on it will pass. They only scan the OBD II to make sure the SES isn't on and the bulb is burned out on the dash or disabled by the owner. Stored codes have no bearing on test results here anyway. A drive cycle for my 99 is, I believe 4 consecutive drive cycles up to operating temp. I would drive it for a day or two before running it through emissions. Hope that helps.
Old Apr 16, 2012 | 09:19 PM
I am in NV, and the SES light does work just happens to be off now so wondering if its a good time to go get it scanned..
Old Apr 17, 2012 | 06:31 PM
Try it out see if it passes. In az you get one free one after your first failure. Should pass if the SES light is off just make sure you buy a new gas cap and put it on before the test. Number 1 reason for failure in az. Good luck.
mr99jimmy
13
Dec 4, 2007 11:57 AM
mr99jimmy
Nov 28, 2007 06:32 PM
agent305
Aug 14, 2007 02:33 PM
speeddemon560
May 27, 2007 01:41 PM
Moretorque05
Mar 22, 2007 06:04 AM
