Will a transmission from a 2002 fit on a 1995?
Old Aug 18, 2013 | 10:45 AM
Colby9255's Avatar
Colby9255 is on a distinguished road
Default Will a transmission from a 2002 fit on a 1995?
just bought the truck and it needs a new transmission, its a 4.3, late 95
Old Aug 18, 2013 | 12:05 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Nope only years 94-95 will work.Anything newer had substancial changes in the electronics to be compatible.
richphotos's Avatar
I dont think so, 95 is a weird year.
Old Aug 18, 2013 | 01:41 PM
chris015's Avatar
not even 94 will work. My trans on my 94 sonoma had to be replaced. Trans shop guy said it wouldnt work that the valve bodys were slightly different. i dunno.
1995 was a one year only deal.
Old Aug 19, 2013 | 04:11 AM
Colby9255's Avatar
damn, so will any 4L60 from 1995 will work?
Old Aug 19, 2013 | 04:36 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
I don't think so, what date was yours made? Half way through 95 im pretty sure they changed it from OBD 1.5 to OBD 2 if its OBD 2 then i think 96-97 will work too. Do some research on that tho, im going from memory. If its OBD 1.5 then i don't even know if a 95 taho or suburban 4l60 would be the same. 95 was so weird Oldsmobile didn't even make the Bravada because of it.
Old Aug 19, 2013 | 10:01 AM
Question
Does the engine have cpi fuel injection or sfi fuel injection?If you have cpi 94,95 will work.96 was a odd ball year,some of the jimmys still had cpi and some of them in late 96 switched over to sfi.
Old Aug 20, 2013 | 10:18 AM
Te valve bodys are exactly the same,they did not change until the more advanced electronic 46le came into the picture.
ONE OPTION if you are unsure would be to have your trans rebuilt which would be a good option if you plan on keeping your truck.
Old Aug 20, 2013 | 08:24 PM
Colby9255's Avatar
thanks for a the help guys! i got lucky and found a 95 parts truck with a good trans, so i shouldnt have an issue
02Goldie_Loks
Tires and Wheels
Aug 11, 2015 06:49 PM
02Goldie_Loks
Tires and Wheels
Aug 8, 2015 01:32 AM
wlorton
Tires and Wheels
Aug 23, 2009 06:12 PM
sfesenko
Dec 12, 2008 10:03 AM
