window & door panel
Old Aug 23, 2008 | 08:19 AM
bamablazer57's Avatar
bamablazer57 is an unknown quantity at this point
Default window & door panel
ok i drive a 2001 blazer ls 4.3. and when i got in it this morning to go to work i pulled on the door handle and the bottom half of the door broke. no biggy ima find another one 4 cheap hopefully but my real problem is my passenger side window won't roll up and i can figure out why. i beleive something came unplugged cause its getting juice. when i roll up other windows if i press the button it slows down the speed of the other windows but it doesn't even get a click or anything. pls help and thnks
Old Aug 23, 2008 | 08:43 AM
bjsx8f's Avatar
bjsx8f is an unknown quantity at this point
Default RE: window & door panel
sounds like you have a window motor out..... if this is the case just simply have to drill out a few rivits then drill holes in the panel to run bolts through and fasten with a nut
Old Aug 23, 2008 | 09:13 AM
If the window isn't jammed, the motor is probably gone as stated above. Once you drill the rivets, the bolts will install in the holes the rivets were through.
Old Aug 23, 2008 | 11:56 AM
bjsx8f's Avatar
yes the same holes sorry i didnt mean to drill all new holes but to increase the size of the original holes to fit a bolt through.
Old Aug 23, 2008 | 11:58 AM
dBsound's Avatar
dBsound is an unknown quantity at this point
My driver's window won't always go up. I finally figured out that if I pry up the part of the door, that holds the window switches (that doing so apparently wiggles the offending wire), the window then goes back up.
It's worth a try. There's just a clip holding it in place. I think I pry backwards on it(just with my fingers), and it pops out. Window goes back up!
Skitzoape
Jan 4, 2014 11:06 AM
teamrojas
Jan 21, 2013 12:30 PM
dano440
May 5, 2012 11:32 AM
Silock
Jul 25, 2011 03:43 PM
02xblazer
Jan 5, 2010 01:58 PM
