Windshield washer pump
Old Jul 9, 2008 | 04:38 PM
Good_Chevy's Avatar
Good_Chevy is an unknown quantity at this point
Default Windshield washer pump
I have a 95 Blazer LT 4 door, and the other day I went to wash my windshield, and very little fluid came out of the driver side nozzle. And then today I tried it, and nothing. And yes the fluid is full. Could it be the pump? Or a clogged line? Is the pump cheap/easy to replace? Thanks in advance for your help.
Old Jul 10, 2008 | 01:02 AM
tkf5651's Avatar
tkf5651 is an unknown quantity at this point
Default RE: Windshield washer pump
Neither is too difficult to replace, just have patience. I would check the sprayers that are actually through your hood before anything else, you will see if you pop the hood you can disconnect the tubing right at the sprayers, and see what you get.
Old Jan 12, 2010 | 11:14 PM
biniecki's Avatar
biniecki is on a distinguished road
I have a similar problem. I my washer line is broken at about the half way point and is coupled together with a vacuum connector. I thought the sprayers may be clogged. I disconnected one end of the connection to see if any fluid came out. Nothing came out and I did not notice any pump noise when the switch was activated. The only thing that happens when the switch is activate is that wipers will still move. I have not checked anything else yet but if the pump is bad where is it located?
Old Jan 15, 2011 | 11:05 AM
Scuba65's Avatar
Scuba65 is an unknown quantity at this point
Same problem here...took the line off the nozzle, no motor, no nothing. My rear washer sprays just fine. Where is the pump for the front?
mh86334
Nov 5, 2010 04:11 PM
corvetteman
Jan 31, 2010 04:27 PM
blzR
Oct 7, 2008 10:21 PM
kaindragoon36
Mar 25, 2006 04:22 PM
fruccoman
Feb 15, 2006 07:08 PM
