windshield water pump
Old Feb 24, 2012 | 04:56 PM
jcortes63's Avatar
jcortes63 is an unknown quantity at this point
Default windshield water pump
neither front or rear water sprays are working., wipers are working good, front and rear,
there is only one reservoir of liquid only one pump is visible without major effort (close to the air filter that goes to the carburetor, I am an old man just kidding)
where is the second one ?
I unplug the one that is visible and not electricity is getting there., I make a little bridge directly from the battery and the pump works.., what may be the problem.
regards
Jcortes.
Old Feb 24, 2012 | 05:06 PM
pettyfog's Avatar
The pump fuse is right next to horn fuse and relay, underhood fuse block
Old Feb 24, 2012 | 05:17 PM
jcortes63's Avatar
Thanks for yout fast answer., but my problem is not replacing the air filter I just mention it., my problem is with the winshield water pump front and rear.
regards
jcortes.
Old Feb 24, 2012 | 05:18 PM
jcortes63's Avatar
sorry it was an add.., I am going to check the fuses.
regards
jcortes.
Old Feb 24, 2012 | 06:11 PM
Common reservoir for both washers, there are two pumps in the reservoir.
Old Feb 25, 2012 | 12:16 AM
Jeklund's Avatar
Jeklund is on a distinguished road
Yup the pump for the rear is the higher up one and the one for the front is at the bottom. It's fairly easy to take it out to check, all i did was pull out the air filter housing and then there were just a couple bolts holding the reservoir on.
hunter05
May 7, 2013 03:29 PM
Good_Chevy
Jan 15, 2011 11:05 AM
mh86334
Nov 5, 2010 04:11 PM
blzR
Oct 7, 2008 10:21 PM
kaindragoon36
Mar 25, 2006 04:22 PM
