Windshield Wiper Fluid
Old Apr 13, 2010 | 09:45 PM
regulator71's Avatar
regulator71 is an unknown quantity at this point
Default Windshield Wiper Fluid
Ok, so I know that some Blazers have the issue where a hose comes apart in the tailgate for the rear wiper. I don't know if my problem is similar or not. So here it is. If I fill the reservoir, I lose about half of the fluid, after 2-3 hours, while the blazer is just sitting there. Now my brother-in-law told me that the little rubber pieces between the motor and reservoir go bad, so I changed the one for the rear motor, but as I was putting gas in the blazer this morning I noticed that it was leaking again... It's in the same place as always, right behind the rear drivers wheel. Now if it would be the hose disconnected in the tailgate would it be leaking from there or more towards the middle of the blazer? Also I'm able to still clean the rear window, as long as there's enough fluid in there. Any advice would be appreciated. Thanks.
Old Apr 13, 2010 | 10:59 PM
old skool luvr's Avatar
"It's in the same place as always, right behind the rear drivers wheel." it sounds like you need to pull the interior and see where the break is.
is any of the carpet wet back there?
Old Apr 13, 2010 | 11:23 PM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
its prob the line that runs under the carpet and u will have wet floors. u can re run it or like me deleat it!
Old Apr 14, 2010 | 07:39 AM
None of the carpet is ever wet, I have a couple of boxes that are always back there, and they're not water damaged or anything.
Old Apr 14, 2010 | 08:56 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Mine came apart at the usual spot and leaked behind the DS rear wheel. Pull the plastic trim panel and take a look.
Old Apr 15, 2010 | 09:04 AM
Alright i will pull it apart this weekend. Thanks for the info.
Old Jun 21, 2011 | 10:20 PM
wvracket's Avatar
wvracket is on a distinguished road
Hey, just wondering if you found your leak. I have the same problem and was wondering how to get in there. Inside uh. I looked all over, but there, don't know why they run wet lines inside but that is just me.
Old Jun 21, 2011 | 10:51 PM
I'm not sure if you noticed the date on this thread. The author hasn't posted in over a year. Not sure if he'll pop in and let us know the outcome. I know the topic has come up in other threads and I seem to remember a thread that has pictures of the typical problem area.
Old Jun 22, 2011 | 06:30 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
I got this one. Yea, it will leak behind the driver side rear wheel. Lift your rear glass, open the lower hatch and pull up on the plastic trim strip that runs across the floor. It is secured with clips. In the valley under the trim, along with several wire harnesses, you will see the black hose, It should be connected to a check valve and then to a 90 degree rubber elbow, then on to the rear wiper. Mine was disconnected at the elbow. The fluid was draining out of a seam at the left side. Plugged it back in and secured with a small zip tie.
Old Jun 22, 2011 | 09:24 PM
wvracket's Avatar
Yea thanks, I missed the 2010 thought it was 11 reading too fast, just excited about fixing problems and finding the solutions on here. My hatch opens with the glass straight up, so will the hose run up the inside of the rear cab?
carlo
Jan 1, 2007 03:03 PM
Brian J. Lesko
Nov 27, 2006 11:58 AM
psyco1887
Feb 27, 2006 02:55 AM
Walleye
Feb 23, 2006 11:42 AM
tdannar
Aug 24, 2005 08:11 PM
