winshield wipers
Old Aug 9, 2008 | 04:07 PM
renee48742's Avatar
renee48742 is an unknown quantity at this point
Default winshield wipers
have problem with my winshield wipers, they some time work, sometime they stay on until I turn my blazer off. one person said that it was the wiper motor,anther said it was the turning switch. does anyone have an idea of what it could be.
Old Aug 9, 2008 | 04:37 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: winshield wipers
It is probably the circut board that controls the wipers you can fix it if you can solder or if you want they are only about $25 new search this forum for a wiper fix it tells you what to fix.
Old Aug 9, 2008 | 07:05 PM
x2 ^^^
Old Aug 9, 2008 | 07:38 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
what year is it, when I bought my 95 brand new it had a recall on the wiper motor, Bad circuit board so I guess it's X3
Old Aug 9, 2008 | 08:37 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
x4 on the circuit board I pulled mine out and resoldered it based on the diy post in this forums. Mine would sometimes work other times not, sometimes work then stop working during the rain. When it wouldnt work the wiper motor would make a jammed motor noise but nothing would happen, but after resoldering all is good.
Old Oct 16, 2009 | 03:39 PM
Chip's Avatar
Chip is on a distinguished road
Help!!! I too have a problem on my 95 with the winshield wiper, but with a twist. I checked out the "wiper fix" thread, and pulled the module with no obvious cracks seen in the modules solder connections. Here is the "twist" I speak of. I can get the wipers to work by lightly pulling on the wiper arm. I thought at first that the wipers were moving too far in their range of motion and that it was a mech. issue, but there seem to be a lot of you with "module" issues so I don't know for sure the nature of my problem.
I do not remember getting a recall notice on this issue and have had the truck since it since new. Any thoughts. Thanks
Old Oct 16, 2009 | 04:24 PM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
I would start by reflowing the solder connections because it doesn't cost anything to try. I'm a circuit board manufacturing process engineer and cracked solder joints are my nemesis. Depending on the size of the crack (most of which are hard to see without magnification) and the ambient temperature, resistances through the circuit can vary greatly. It could easily be that the board can provide just enough power to the motor that it needs your "help" to make it work.
Gotta get rid of variables one at a time to home in on the problem. Reflowing is the simplest, cheapest way to start.
Good Luck,
Garry
Old Oct 17, 2009 | 04:45 PM
Chip's Avatar
OK I will take a shot at it. Thanks!
inzone
Dec 31, 2014 01:43 AM
darknight
Aug 22, 2011 08:55 PM
ukfanz
Dec 24, 2010 02:04 PM
Jonas
Aug 9, 2010 06:29 PM
scoot
Jan 11, 2005 02:38 AM
