wipers stopped working 1997
Old Mar 29, 2009 | 04:40 PM
blzR's Avatar
blzR is an unknown quantity at this point
Bump
Where is that "wiper module" located?what are those 3 black relay looking fuses are that are at the back of the engine compartments firewall??(not glove box relays)
Old Mar 29, 2009 | 06:15 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
On the firewall, right in front of the steering wheel.
blzR's Avatar
Ok never mind those relay questions,they have nothing to do with wiper functions..what a issue i am having trying to find the culprit short.I do know that this far it is a
positive(+) wire/contact/short,as when i put the tester to the batt directly from the wiper clip connector the neg is 12v,but positive is 4volt..is there another fuse block under hood somewhere??
Old Mar 29, 2009 | 07:01 PM
blzR's Avatar
Thank you very kindly dBsound, off right now to go see!
Old Mar 29, 2009 | 07:21 PM
blzR's Avatar
There is only wires and connectors,perhaps 1995 blazers are different?
Old Mar 30, 2009 | 01:21 PM
blzR's Avatar
Bump!
I am only bumping so frequently because i have to put everything back together,only to tear it all apart again next weekend.
Old Jul 23, 2009 | 07:15 PM
roflwaffle08's Avatar
roflwaffle08 is on a distinguished road
Hey, thought this would be the right place to post.. I had issues with my windshield wipers, they would sometimes work and then sometimes not.. So I took out the wiper module, the green PCB board, and there was a burnt out connection from the relay switch to the wipers.. soldered over the bad connection with a wire and bam, things are working fine.. inspect the PCB board over very closely, make sure all soldering connections are working fine.. the reasoning for my bad connection was likely that the wipers were working too hard and the small trace couldn't handle that power.. easy fix, just make sure to look over the board really well..
pinecone
Jun 13, 2011 05:59 PM
Jonas
Aug 9, 2010 06:29 PM
jstutzman
Dec 19, 2009 03:27 PM
acedrr03
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jan 17, 2008 10:37 AM
mac6135
Dec 8, 2007 09:18 AM
