won't idle
Old 08-07-2021, 03:40 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
OK. Again can you see the TPS value in your scanner?
George
  #32
Old 08-07-2021, 03:42 PM
Oldladystrailrig's Avatar
Oldladystrailrig is on a distinguished road
No I don't think I am able to.
  #33
Old 08-07-2021, 03:49 PM
GeorgeLG's Avatar
OK then same exact set up. +5V ref, -5V return and a signal wire out. The sensor is a variable resistor and the voltage should smoothly swing between 0 and around 4V with key on engine off and sweeping the throttle back and forth. Same drill, check power, check ground, check output voltage.
George
  #34
Old 08-07-2021, 03:51 PM
GeorgeLG's Avatar
Start with everything hooked up key on engine off and monitor the voltage output while sweeping the throttle back and forth. 1-4V and smooth?
George
  #35
Old 08-07-2021, 03:52 PM
GeorgeLG's Avatar
At the sensor that is by back probing or jumping the connector.
George
  #36
Old 08-07-2021, 03:53 PM
GeorgeLG's Avatar
Sorry, 1-4V.
George
  #37
Old 08-07-2021, 04:02 PM
GeorgeLG's Avatar
Wire colors should be signal (dk blu), +5V ref (gray), -5V return (blk).
George
  #38
Old 08-07-2021, 05:03 PM
Key on engine off .7V across sensor output (blue) and - return (black) with no throttle and 4.5v at WOT. Moves smooth and steady
  #39
Old 08-07-2021, 05:31 PM
GeorgeLG's Avatar
The P0122 code is set when the TPS sensor output drops below 0.1V so we have not reproduced the fault yet.
Do the same TPS output measurement with the engine idling and try some slow smooth rpm changes.
Measure the voltage at +5V ref and -5V return with everything connected, once with key on, engine off and once while idling.
George
  #40
Old 08-07-2021, 05:35 PM
Back to the map sensor issue for a second. I still have the fused jumper across 5v ref and sensor output. I figured I try to clear the p0107 code map sensor low voltage but it's not clearing. I checked voltage across 5v ref and 5v return with key on engine off and I have 5v like I'm supposed to. But when I start the engine it's dropping to 0v. This same exact issue is happening with the tps also
Quick Reply: won't idle
