Won't start
Old 02-08-2011 | 10:00 AM
alec.m's Avatar
alec.m is on a distinguished road
Default Won't start
replaced the fuel filter my 95 4.3 vortec only ran once now it wont start. also replaced the fpr spider harnest....im lost any words of wisdom
Old 02-08-2011 | 12:03 PM
blazinloud's Avatar
fuel pressure test
Old 02-08-2011 | 10:19 PM
cg.chavira's Avatar
cg.chavira is on a distinguished road
I used to own a '95 s10 brazer. I bought it new and had a lot of issues with the entire fuel system. Since you already replaced the fpr and harness have you tried checking your fuel pressure. It might be your fuel pump failing. I had to spray fuel starter down its snorkel to get it to start. The pump would keep the engine running but as soon as I parked it, I would have to spray it again in order for it to start.What happens is that you injectors are poppet type injectors and they need between 50-60 psi. So if your pump is weak it will not have enough pressure to start.
andrewrj
05-06-2012 07:28 PM
princered72
09-13-2011 10:36 AM
Dark Rider
08-08-2010 11:57 PM
1BSBAKER
08-11-2009 10:54 AM
Irish10Hockey
11-13-2008 02:48 PM
Quick Reply: Won't start
