Won't start after body lift
Old May 4, 2015 | 06:58 PM
madmaxxed's Avatar
madmaxxed is on a distinguished road
Default Won't start after body lift
I took my time installing a PA body lift in my 1999 blazer. Time meaning here and there within a 2 week span. My blazer won't start now. It fired for about a second and now only turns. The only electrical items touched were a few ground connections which have been reconnected with clean metal on metal contact. It doesn't take long for the battery to drain trying to start it. I did replace the alternator a while back. Do you think I could use a new battery? I don't know how old it is since I'm the second owner but I had no issue starting it before the BL install. The battery was out of the blazer for almost 2 weeks as well. Thanks.
Old May 4, 2015 | 07:04 PM
LeWhite's Avatar
Think how long the battery stayed in the store before you bought it! You could always put it on a trickle charger overnight. Dont use fast charger if at all possible.
Old May 4, 2015 | 07:06 PM
madmaxxed's Avatar
I've tried jumping it too and the engine just turns and won't fire.
Old May 5, 2015 | 04:05 PM
newguy's Avatar
sounds like a passlock problem. Of which I`m no help
Old May 5, 2015 | 06:20 PM
madmaxxed's Avatar
Pass lock problem?
Old May 5, 2015 | 06:23 PM
LeWhite's Avatar
Pour a thimble full of fuel under the hat and rescure. Will it start?
Old May 5, 2015 | 06:25 PM
El_Beautor's Avatar
Passlock is the factory anti-theft system. If it is locking up there will be a security light flashing on your dash while you crank the engine.
Old May 5, 2015 | 06:44 PM
madmaxxed's Avatar
Yes briefly. Then stalls out again.
Old May 5, 2015 | 06:50 PM
madmaxxed's Avatar
I'm not seeing the security light flash when I try to turn over the engine.
Old May 6, 2015 | 01:10 AM
LeWhite's Avatar
Take the key out of the ign.
place your ear next to the left rear tire.
have a friend insert the key and turn past the first click (acc) to the to the second click (run) position.
do you hear the fuel pump run for three sec then quit?
report back.
