Won't start after body lift
Old 05-16-2015, 07:16 PM
madmaxxed's Avatar
madmaxxed is on a distinguished road
Now I'm completely lost. I replaced the fuel pump today. I tried the passlock bypass last week and put the wiring back to the original layout. No luck with starting. I'm not even getting fuel. I had to keep jumper cables on while attempting.
  #22
Old 05-16-2015, 09:32 PM
LeWhite's Avatar
Check power to pump
check pump to chassis and body ground
check for fuel pressure from pump
  #23
Old 05-17-2015, 07:22 AM
newguy's Avatar
this may work also, and its free. http://my.cardone.com/techdocs/pt%2077-0011.pdf
  #24
Old 05-17-2015, 05:45 PM
madmaxxed's Avatar
Fuel pump is definitely not getting power. I cannot hear it kick on and I'm not getting any fuel up front.
  #25
Old 05-17-2015, 06:32 PM
LeWhite's Avatar
Re: you have put power in at the FP prime hole at the fuse block:
the relay is good;
there is no power at the FP gray wire at the tank.
If all are correct than your lifting has severed the big gray fuel pump wire!
  #26
Old 05-17-2015, 06:52 PM
madmaxxed's Avatar
The relay is functioning. I Will pill the tubing from the wiring and follow the gray wire. This is killing me.
  #27
Old 05-17-2015, 08:04 PM
newguy's Avatar
I predict and end to this coming soon
  #28
Old 05-18-2015, 05:28 AM
madmaxxed's Avatar
I hope so.
  #29
Old 05-23-2015, 06:18 PM
madmaxxed's Avatar
She lives! Probably replaced the fuel pump for no reason. It could've been as simple as low voltage from the battery. I didn't think it would've been the issue if if it was turning over the motor. I also cut the grounds from the fuel pump harness, soldered them to a 14awg wire and grounded it directly to the frame. She fired right up!
  #30
Old 05-23-2015, 06:42 PM
newguy's Avatar
Great news!
Quick Reply: Won't start after body lift
