Y-Pipe O2 sensors
Old Aug 26, 2008 | 12:39 PM
intake's Avatar
intake is an unknown quantity at this point
Default Y-Pipe O2 sensors
First a little info:
'98 Blazer going to be running Microsquirt Sequential (piggy backed... keeping stock ECU mainly for ABS and SRS)
will be turbo'd with WB O2
Now to my question... I'm going to get a custom y-pipe fabbed up at 2.25" or 2.5" not sure yet and was wondering since I will be running a standalone for fuel/timing can I delete HO2S Bank 1 Sensor 1 and Bank 2 Sensor 1 when I replace the y-pipe?
stock exhaust currently has
HO2S Bank 1 Sensor 1 - drivers side y-pipe
HO2S Bank 2 Sensor 1 - passenger side y-pipe
HO2S Bank 1 Sensor 2 - pre-cat
HO2S Bank 1 Sensor 3 - post-cat
Old Aug 26, 2008 | 02:40 PM
Default RE: Y-Pipe O2 sensors
Does the microsquirt use any of the signals pertaining to fuel trim from the factory PCM? If it does, then you cannot delete the upstream (B1S1, B2S1) sensors. The PCM will freak out and richen the mixture to tabled values.
As far as the pre-cat and post-cat sensors go, you will need to delete the codes for them from the factory PCM via a tune or else have a check engine light that is on all of the time.
What are you going to be doing that you will need the add on fuel management device that cannot be accomplished via a tune?
Old Aug 26, 2008 | 04:22 PM
intake's Avatar
Thanks, that's what I thought. But since the MS-II Sequencer is a fully programmable/tunable standalone engine management controller I won't have to worry about the PCM freaking out as it will not be controlling or have access to any of the fuel or timing.
I could get a custom tune for the stock PCM but I would rather use standalone engine management and have full tuning ablility any time I want and I will also be able to control boost without any other addon boost controller.
Old Aug 26, 2008 | 07:46 PM
You will still have to program out all of those sensor codes so that the check engine light does not stay on.
Old Aug 26, 2008 | 08:12 PM
WolfPack's Avatar
Annndddddd its a blazer.
just throwing that out there.
Old Aug 27, 2008 | 10:34 AM
intake's Avatar
ORIGINAL: swartlkk
or just disconnect it
Old Aug 27, 2008 | 10:35 AM
You could do that too. If you live in a location that does inspections through the diagnostic link, then you will need to "fix" those problems prior to an inspection. That is the main reason why I stated that they should be removed. Once removed, you won't fail an inspection because of it.
swartlkk
Apr 24, 2006 02:37 PM
Bgray
Engine & Internal
Jan 15, 2006 05:28 PM
LittleDan911
Dec 14, 2005 07:12 PM
mpp1970
Apr 7, 2005 06:22 PM
Blade69
Jan 20, 2005 01:12 AM
