ZR2 runs hot going down road
2003 ZR2
My ZR2 will idle at temp just fine, but if I run it down the road (with ac on) it starts getting hot and seems worse with faster speed (3/4 gauge). I removed the mechanical fan and installed electric fans, and have also pressure washed the fins of the radiator and condenser. Im not sure what to look at next or why it would idle fine at temp (idled for 45 minutes just under 1/2 gauge) but get hot running down the road. Any suggestions?
2003 ZR2
The recommend engine flush is an lengthy process....not just a matter of connecting a garden hose. Do a quick search and you should find it. Besides the radiator some of the water passages can clog up. When I changed my intake manifold gasket the rear passages were almost totally clogged. Although not common your water pump impeller could be going but normally the first thing to go wrong with a water pump is the shaft bearing.
Well I got a new water pump and Tstat today for $20 after turning in fan clutch tool. Gonna open the system to replace those (I now the stat sticks a little). While I'm in there I wanna see the condition of the residual fluid.
It would be best to verify coolant temp with a scan tool. Compare the Engine Coolant Temperature sensor, (ECT) to the Inlet Air Temperature sensor, (IAT) after the vehicle has set for 8 to 10 hours, (before starting the engine). They should be within 2 degrees of each other. Don't trust the dash temperature gage, they're not known for their accuracy.
Depending on the CFM of the electric fans, and what temperature the sensors are set for, the fans might be causing part, (possibly all) of the problem. At highway speeds, the natural air flow across the radiator is greater than the fans can provide, so they end up restricting air flow if they're on. They should be off, (free wheeling) when you're at highway speeds. That's the beauty of a fan clutch, it only engages when it's needed, otherwise it's free wheeling. Could be your original fan clutch wasn't working properly.
You mentioned that you used a power washer to clean the condenser and radiator fins.... not a good idea.... the force of the water can easily bend the fins. When they get bent, the air flow is restricted. Harbor Freight has a fin straightening tool for $5. The upper radiator hose should be hot at the radiator and the lower hose should be noticeably cooler. If it's not, suspect a restricted radiator.
zakm0n
01-10-2011 11:42 AM
ravenhurst
15
04-26-2009 07:53 AM
gw2009
03-19-2009 08:54 PM
