ZR2 Upgrade?
Old Aug 26, 2021 | 12:57 PM
kmenc67's Avatar
kmenc67 is on a distinguished road
Default ZR2 Upgrade?
Can a standard 4WD model be upgraded to the ZR2 suspension or are there any other structural differences? For example can a regular 2003 4WD 2 door Blazer be upgraded with a ZR2 suspension from the same year?
Old Aug 26, 2021 | 02:45 PM
I want to say the mounting locations are different on the base 4x4 and the zr2 frame, for the control arms. Maybe difference in the leaf spring locations?
If you were to take the whole frame, and swap the body, I think that would be the way to achieve this...
Old Aug 26, 2021 | 03:02 PM
kmenc67's Avatar
Thanks. That kinda puts me back to square one unfortunately. The situation is I have a 2003 ZR2 with considerable salt rot on the front crossmember/subframe. It's not an immediate issue but sooner or later the mounting point for the lower control arm is going to give out. I looked at getting a donor frame and just DIY moving everything over a period of a few weeks, but I have no way to lift the body off or move it to a new frame. I havent been able to find any other ZR2s within a reasonable distance, so I thought maybe I could upgrade a standard 2-door 4WD Blazer with the suspension from my current vehicle. I know I should just junk the thing and get over it, but it runs fine and it just feels like a waste.
Old Aug 26, 2021 | 08:11 PM
eshaw's Avatar
I don't know how much work you're into but you could always SAS it.
Old Aug 26, 2021 | 11:35 PM
Thats what I would do^^^^^^
Considering the mounting the CA are going, installing leafs up there would a big upgrade!
Dan Watson
Aug 1, 2019 05:52 PM
Redneckrebal15
Apr 4, 2016 09:55 PM
Joshs4x4
May 13, 2012 10:36 PM
Red 96'
Lifting Tech
20
May 4, 2010 02:21 PM
woodman619
Apr 13, 2007 03:58 AM
