Gap, is this true
Old Jun 15, 2016 | 11:53 PM
newguy's Avatar
Default Gap, is this true
Copied from another forum. This bulletin is being revised to bring attention to the Set Gap Per Vehicle Specification on the ACDelco® Iridium Spark Plug Boxes. Please discard Corporate Bulletin Number 03-06-04-060 (Section 06 -- Engine/Propulsion System).
• A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed.
• The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01 mm (0.040 in) when the spark plug is made.
Notice: The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gaped should not be used.
Old Jun 16, 2016 | 11:39 PM
AJBert's Avatar
First I've heard of this. I've always gapped my plugs at .060 yet don't recall which plugs I put in last time. Maybe I need to pull one or two to see how they look.
Old Jun 17, 2016 | 06:13 AM
All iridium plugs will be gapped to the application by the manufacturer. The fine wire design makes it VERY difficult to properly gap the plugs as the center electrode can be bent or broken if improperly handled.
This is the first I have heard that the gap dropped for these plugs though.
mojoman13
Jul 8, 2009 07:12 AM
willjones
Jan 30, 2008 07:54 PM
murfthesurf4
Nov 26, 2007 11:01 AM
2klt
Mar 19, 2007 10:49 PM
the_mind
Headers, Intake, & Exhaust
Jul 22, 2005 06:06 PM
