How to: DIY Roof Basket (in progress) - DISCUSSION THREAD
Old Nov 4, 2010 | 08:17 PM
warthogdriver's Avatar
Default How to: DIY Roof Basket (in progress) - DISCUSSION THREAD
Ok, so being a mall crawler on a budget and wanting a roof basket what do you do?
bueller? bueller?
you look to your local big box one stop fix it shop...(home depot ftw)
and the glorious conduit selection
(and some **cough**jeep forums)
this DIY also is based on some MIG welding - sorry
*********all cash-Ola amounts in dollars and units in inches*********
so here we go:
1. tools
drill press / drill
hacksaw and miter box / metal blade on miter saw
measuring tape
3/4" drill bit
something to mark with (marker)
grinder - sand paper
MIG welder
patients
2. materials
for the outer frame:
1" emt conduit 10' length - 3 @ 5.50
90 degree emt conduit elbow - 8 @ 3.50
joint emt conduit - 16 @ 1.50
(get steel ones not zinc..pics show wrong joints)
floor of basket and rail supports:
1/2" emt conduit 10' length - 4 @ 1.50
grand total of 75.00 (no taxes included)
this does not include paint/finish material or mounting equip.
i am using u bolts for the mounting.
3. what your making
now for my tastes i went with a basket with dimensions of
67" X 41" out to out
7" tall
***out to out is based on mounting to rails of stock roof equip.***
4. whatcha doin'
so after you have all your conduit goodies here is what we do.
take your cutting method of choice and do some chopping:
1" dia.
4 @ 22" length (ends for outer rails upper and lower)
4 @ 47 1/2" length (sides for outer rails upper and lower)
1/2" dia.
8 @ 40 3/4" length (floor of basket)
14 @ 7" length (rail supports - determines basket height so make it your own)
what that all looks like
5. assembly
now take the to side lower rails and lets make some holes.
now the spacing is up to you, i went with 7 1/2" on center for the floor of the basket. again spacing is up to you.
this part is tricky. make sure you maintain the center line and drill away. this is probably the biggest p.i.t.a. part.
you should get something like this when done.
now that you have done all that assemble for a test fit.
you should have what looks like the floor of a roof basket.
now with the joints i used i plan on welding them in place and calling it good
i don't believe using the screws that come in the joint will do the job.
for the side rail supports you repeat the drilling of the holes.
now the spacing on the side supports will be determined by the floor support spacing. i went with 3 supports on the ends and 4 on the sides, all spaced evenly.
i feel that this will support anything i find while tromping around the mall.
(test fit)
test fit, not squared all the way but you get the idea, zip ties for temporary hold.
and no the light are not staying there.
now if you have made it this far and are ready to weld this baby up..be sure to grind at the weld points...this is galvanized so you need to remove that as best as you can at the weld points.
paint and finish as you see fit. what the heck, go ahead and throw some lights on that bad boy...you know you want to
6. and where we stop
as of today i have not welded or applied paint.
i hope this helps to jump start some projects.
i think this is a good starting point and gets the idea across.
and if you do beat me to it post up some pics
Old Jan 6, 2011 | 06:32 PM
ok,
with the January thaw last week it hit mid 50's so i did some painting in the sun
close up
i am going to wrap up lights and toss it on soon.
Old Jan 6, 2011 | 08:21 PM
ABN31B's Avatar
Damn man! at first i was like: he's building a toddler bed???
then as it progressed.... i was like
That turned out AWESOME! very nice work man.
looks beastly! now what's the plan to make the roof rack stand up to more than 200 lbs
*EDIT* the fact that you did this in November and it flew under the radar is a travesty!
Old Jan 7, 2011 | 03:31 AM
thanks, yup 200lbs plus shouldn't be a problem..holds my wide load
yeah it looks like i am gonna be set for either zombie Apocalypse....or extended jungle excursion.
on the toddler bed thing....yeah thats what my brother said.....
"you making toddler bunk bed system????????"
Old Jan 9, 2011 | 08:30 PM
ABN31B's Avatar
I meant the roof of the truck is only rated for 200 lbs
if you do the jungle busting with that rack, you better take a camera
Old Jan 9, 2011 | 10:03 PM
mdehoogh's Avatar
Looks awesome. Personally I would have made it a little shorter or else bolt it directly to the roof and remove the stock rack. Great idea though making it yourself
:thumbs-up:
Old Jan 9, 2011 | 10:46 PM
yup she sits a little high...lights fit in between upper and lower rail.
it is replacing the stock rack...pic was for mock up measurements...
i want height just not that way
Old Jan 10, 2011 | 02:06 PM
mov4x4's Avatar
mov4x4 is on a distinguished road
I think it looks great! I figured this would have gotten a lot more attention than it currently has.
Old Jan 10, 2011 | 05:24 PM
neo71665's Avatar
Looks great, if ya were closer I'd offer to use my 1 inch hand bender and do away with having to weld up all those premade 90s. I actually plan on building one kinda like this but I'm gonna try to make mounts to bolt it to the factory cargo rack mounts and do away with it.
Old Jan 10, 2011 | 05:58 PM
thats where i sit right now...to damn cold to go out and monkey with making mounts.
soooo i wait. hopefully no zombie apocalypse till it warms a bit.
