How-to: Installing AC plugs and power inverter. -- DISCUSSION
i am about to perform this install. all i need now is some longer wire to go from the ac plugs to the back of the center console. its a 400 watt inverter. it also has a usb power outlet. im going to measure the power coming out to see if it is sufficient enough to power my usb hub need for my truckputer.
Nice looking install, but you may want to put an inline fuse on the 4AWG cable you have running from the battery hot post through the firewall. One short on that wire will kill your battary fast if you're lucky. If you're unlucky it will weld itself to the frame, damage anything near it and possibly start a fire.
Ask me how I know...
