How to replace Torsion bar mounts.
Old Mar 11, 2012 | 04:24 PM
gojorg's Avatar
I have a 2000 too, ours is different, I didn't have time to check if there was any play with the them but I got to check because I have a clunk under the truck not quite in the front or the rear and nobody have been able to find what is making it.
This is what it looks like for 95 -up
MOOG K700356 Torsion Bar Mount Kit | eBay
Old Mar 11, 2012 | 04:35 PM
ravenhurst's Avatar
ravenhurst is an unknown quantity at this point
Yeah that's the same part number that rockauto.com has. I guess they are the same for both sides. (And rockauto has it for a few $ cheaper)
I'm going to order two new tbars and mounts. I imagine I'll figure out how to change them when they come in.
Ok, just a question to be answered that I'm concerned about. I had the front end on jackstands, and there was quite a bit of play in the cross member. With weight on wheels, there is hardly any. Are these mounts still considered bad? I know there is a rubber stopper, so maybe that's what caused the play. What is the full procedure to check for a bad mount? I'm still going to replace the T-bar, because they are pretty badly worn out, and look inexpensive and easy to replace.
Also found this on youtube, which is for a Chevy Colorado, but the mounts look similar. http://www.youtube.com/watch?v=EprZDM24hyY
Old Mar 11, 2012 | 06:40 PM
chris015's Avatar
if its loose/has play,replace them.
Old Dec 12, 2013 | 11:28 AM
04SSBlazer's Avatar
04SSBlazer is on a distinguished road
have this same problem ( i think) with my 2004 anyone have picture so i can see what im looking at
Old Jan 28, 2025 | 06:53 PM
Jrod96blaze's Avatar
Jrod96blaze is on a distinguished road
Default Torsion bat monts...how tight..??
How tight should I tightened the torsion bar mounts that are against the frame?
98BlazerLT4x4
Oct 28, 2008 08:18 AM
c0a8l0v6i8n9
Sep 3, 2008 07:51 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
S10Blazer
Dec 23, 2007 10:47 AM
fernandoh
Oct 19, 2007 02:26 AM
