How-To: T-bar Crank - DISCUSSION
heres a tough one...i bought a lowered 2003 2 door 4x4 blazer...i know its lowered with blocks in the back, not too sure what its lowered with in front. Went to a off road shop today and the guy said it needs new torsion keys because the original owner put in lowering ones...i came up and did a quick torsion bar cranking myself and got lift out of it...how do i tell if the torsion key is the original one or a lowered one? How far up into the key should the bolts be? Any pictures of before and after torsion bar cranks of the actual bolt u turn?
Usually there's about 3/4" from the head of the adjuster bolt to where it threads into the adjuster. If you bring your RPO codes to a GM dealer, they can figure out what keys are supposed to be in there.
is the 3/4" at stock height or after the lift?
would rivets be a good alternative to those 2 screws you recommended taking out? seeings how they would sit much more flat... but thats just a thought... btw, i am about to do this to fit my new 31's... so if anyone is interested in selling me a 1.5-2 inch shackle lift PM me please... and thank u for the insight on this, i think itll b veryyy helpful..
