How-To: T-bar Crank - DISCUSSION
Old Apr 10, 2011 | 08:02 AM
  #101
Originally Posted by fishstick002
any one here
If you have a question pertaining to this tech article, then ask it. If you have a question about lifting in general, please create a post in the appropriate forum section (lifting tech). This section is for discussion of the actual article and in general is not for discussion of technical questions..
Old Apr 10, 2011 | 08:28 PM
  #102
oktain's Avatar
Old Apr 12, 2011 | 05:49 PM
  #103
gettochild1985's Avatar
gettochild1985 is on a distinguished road
2'' shackles for 2nd gen are on ebay, $52 canadian. just got mine. they only took days to get here from L.A.
Old Jul 12, 2011 | 12:59 AM
  #104
lazer2000's Avatar
lazer2000 is on a distinguished road
Here is 1 question.
In the photo story of the T-bar crank posted by a_tack, it says to jack up the front of the vehicle before adjusting the T-bar bolts.
But in this thread, it is mentioned that the T-bar adjustment should be performed on a level surface, without jacking up the vehicle.
What is more recommendable?
Old Jul 12, 2011 | 06:59 AM
  #105
The proper way to adjust the jack bolts is with the weight off the front end. To check your adjustments, you have to put the truck back on the ground and then drive forward (or backward) at least one truck length to settle the suspension. Then repeat until you get the desired height.
Old Aug 2, 2011 | 06:30 PM
  #106
aneill75's Avatar
aneill75 is on a distinguished road
Wouldn't the front sway bar need to be disconnected to accurately adjust the torsion bars?
Aaron
Old Aug 2, 2011 | 06:49 PM
  #107
The sway bar isn't going to make that much of a difference unless your front end is an inch or two higher on one side.
Old Sep 14, 2011 | 09:21 PM
  #108
gatorboy44's Avatar
gatorboy44 is on a distinguished road
Talking
Good post, I wish I would have seen this before I did mine, I didn't use a sharpie I just watched my wratchet very closley.
Old Sep 24, 2011 | 01:14 PM
  #109
BlazHerZR2's Avatar
BlazHerZR2 is on a distinguished road
now with shackles and a TBar crank should you get 2in bigger shocks if your doing 2 inches all around
Old Sep 26, 2011 | 12:37 PM
  #110
Benedict1337's Avatar
front shocks I'd recommend. rear shocks you don't have to unless you want to. If I were you I wouldn't crank the tbars at all. will save you a lot of problems
