so you want a tire carrier on your 4 door?? - DISCUSSION THREAD
Old Jan 21, 2013 | 12:39 PM
  #411
Mczuk's Avatar
Mczuk is on a distinguished road
I have one on the way. My stepfather own's a used car lot / garage and he picked one up for me. He even fixed it up and painted it before they sent it. Now the waiting game begins, it will take about 6 weeks for it to get here.
Old Jan 29, 2013 | 10:17 PM
  #412
mdehoogh's Avatar
I had some concerns when I first installed mine so I thought I'd post an update for anyone considering this mod.
I've had my spare tire carrier on for about 2 years now. When I installed mine (literally, a hackjob) I cut away a lot of metal from the inside body panel in order to gain access to the holes in the outer panel. I have no support bar other than a few thick fender washers on the inside.
To my surprise, there has been no warping or bending and it looks exactly the same as when I first installed it. I've also never had the gate open on it's own, although I did leave it unlatched once and drove about 40 yards before noticing (it was dark out lol)
Old Jan 30, 2013 | 12:32 PM
  #413
Diaita's Avatar
Thanks for the update! Is it a 31" tire you have on your carrier? I have had a carrier to put on my Blazer for a while, but I am still apprehensive about hanging a 35" tire on sheet metal. Still, I love the factory look of it!
Old Jan 30, 2013 | 02:41 PM
  #414
mdehoogh's Avatar
Yep! I love the way it looks
Just FYI, the tire blocks a good portion of the rear window. A 35" tire might make it unusable (not a huge issue though)
Old Jan 30, 2013 | 04:57 PM
  #415
Diaita's Avatar
No doubt. The 31" on my old ZR2 was bad enough, but I got used to it. I think I'll modify the carrier so the tire sits closer to the tailgate as well, might help with the leverage of an offset wheel and heavier tire.
Old Jan 30, 2013 | 06:22 PM
  #416
warthogdriver's Avatar
mine is riding a 33 since i lifted...no problems at all.
Old Jan 30, 2013 | 06:26 PM
  #417
Diaita's Avatar
I think I'm over-analyzing and stressing for no reason. I haven't read of anyone having issues with it. Thanks for your input!
Old Jan 30, 2013 | 06:47 PM
  #418
well if ya look at it the carrier has 3 mounting points when closed...more then enough for the tire/wheel. when opened you may have concerns...but i would think slight reinf. would be enough...thats why i tied the top and bottom bolts together on the inside of the inner body panel with a length of steel stock from the depot.
Old Jan 31, 2013 | 04:29 PM
  #419
mdehoogh's Avatar
Yeah I try not to leave the carrier open for any length of time which kinda sucks. Not sure how much damage I could do by leaving it open but that's a lot of weight. It's also far enough away from the hinges to generate a lot of downward torque
Old Feb 1, 2013 | 04:21 PM
  #420
i have left mine open for hour or more at least all the time. when working on the ride i use the back as a tool shelf / work bench...no problems.
