2ohm or 4ohm?
Old Jan 27, 2009 | 04:33 PM
mccainthepain's Avatar
mccainthepain is an unknown quantity at this point
Default 2ohm or 4ohm?
I'm looking into getting 2 MTX TR75's but i don't know whether i should get the 2ohm or the 4ohm subs.
is there a power handling difference? The subs are 500 rms and the amp is 1000 rms at 2ohms.
Old Jan 27, 2009 | 04:35 PM
mdehoogh's Avatar
Default RE: 2ohm or 4ohm?
You'll want to get 2ohm subs.
Old Jan 27, 2009 | 04:52 PM
But say if i wanted to run 1500watts at 1 ohm for a short period of time like at a comp?
which is better then?
Old Jan 27, 2009 | 05:02 PM
mdehoogh's Avatar
You can wire up two 4ohm DVC subs to have a nominal 1ohm load. What amp is it? Are you even sure the amp is 1ohm stable?
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Old Jan 27, 2009 | 05:09 PM
jagblazer01's Avatar
if the amp isnt 1ohm stable you wont have much luck trying to run it at a comp with out it going into protect. you can run a 1ohm stable amp at 2ohms but you can run a 2ohm stable amp at 1 ohm
Old Jan 27, 2009 | 05:11 PM
the amp is a MTX TE1501D
500watts rms at 4ohms
1000watts rms at 2ohms
1500watts rms at 1ohm
Old Jan 27, 2009 | 06:43 PM
get 2 dual 4ohm woofers and you will be able to run 1500w daily.
Old Jan 28, 2009 | 09:43 AM
but will that overheat the subs since their rms is only 500watts each?
Old Jan 28, 2009 | 10:42 AM
just keep ur gain set a little lower and you'll be fine
Old Jan 28, 2009 | 12:45 PM
blazinloud's Avatar
whatever happend to the argument that power does not blow speakers? and why do people tell others to set their gains low to avoid this? my pioneer deck has 2v outputs.....with the lack of a dmm i set my gains to the highest setting, which is +9 (of the available 0, +6, or +9) on my alpine mrd-m501.
the best protection for your drivers is your ear, if they're bottoming out, or are distorting, then you know you have problems. The sundown audio nightshade for example is a high end competition sub rated at like 1000rms(or around there) but can take 6000+watts on burps and be fine......power does NOT kill subs
