6.5" in Door Panel 1st Gen S10 BLAZER
Old Oct 30, 2013 | 02:31 AM
jvde's Avatar
jvde is on a distinguished road
Default 6.5" in Door Panel 1st Gen S10 BLAZER
Hey guys my first post here - Going to post pics u of my Audio Install soon on 88 chevy blazer..
heres what ive done so far:
removed all interior plastic
Useal Interior (dynamat) from home depot. works great!
Boss 7" Flip Out Head Unit
6x9 Component speakers in back - replaced ash trays with tweeters (mod)
PolK audio 4x6 Up front
Basslink in Back for Bass
Sounds Amazing - but i want more speaker already
searching around here and cant find anyone who has modded there front door panels on first gen 2dr S10 Blazer to fit 6.5" but know it has been done.. anyone have any pics or experience?
also all i need to do to add more speaker is add an amp right? i can wire extra speakers in series..?
thanks
Old Oct 30, 2013 | 10:24 AM
dirt101's Avatar
dirt101 is on a distinguished road
I wouldnt drop another penny until you replace that boss HU with something better. Seriously the heart of your sound sytem has to be solid before you go adding a bunch of other stuff.
Old Oct 30, 2013 | 10:28 AM
dirt101's Avatar
but if you do want to add 6.5s in the door your going to need to build someting like this. I started working on these, but then sold my truck before I ever tested them.
Attached Thumbnails 6.5" in Door Panel 1st Gen S10 BLAZER-20131007_152728_zps6ed5877e.jpg
Old Oct 30, 2013 | 11:58 PM
jvde's Avatar
lol funny you said to drop the Boss and then posted pic of the Pyles
looks awesome tho, was thinking two in each side would bang! ill post pics up soon of my install.
as for boss just wanted a flip-out knew it was ghetto, figure with good amp and crossover it wont matter?
Old Oct 31, 2013 | 12:02 AM
jvde's Avatar
heres clean install just for the sake of this thread.. notice the tweeters
Old Oct 31, 2013 | 01:05 AM
Thogert's Avatar
Haha, Boss and Pyle, this thread is off to a great start.
While you can wire new speakers up in series (NOT in parallel though!), it will drop the power to both by at least half. I would suggest getting an amp, and one set of better speakers for the front. This will sound much better than 4 speakers just thrown in there on head unit power. Which brings us to the head unit. An amp only amplifies (imagine that ) the signal it gets from the head unit. So if the head unit is not very good, and doesn't send a good clean signal to the amp, the amp will just make the bad sounds already there more apparent.
A good head unit and a decent set of speakers with a decent amp will provide great sound. Usually far far better than 4 or 6 cheap speakers on an amp on a cheap head unit.
Old Oct 31, 2013 | 01:56 AM
jvde's Avatar
yeah def. adding amp if i add more speakers .. thinking about adding a mini 2channel amp into the glovebox. and wiring down to door panels. something like the Rockford Fosgate PBR300
see if this is correct:
2 channel amp
4 speakers total - 2 left door panel - 2 right doorpan
wired in Series on each side.
2 channel right? or 4 channel, so each get a channel?
would be cool to do front most to :front: output.
and for the two on the rear half of door panel wired to :rear: output.
so there is a little bit of separation when adjusting fader.
also want too add a crossover.
lets get something straight - the boss headunit sounds better than you would imagine. their build quality is reasonable for the price, def beats the base model kenwood/alpine units.. I would say Boss headunits better than jensen. power aucoustic all the other cheapies - so dont knock it till u try it .. Head Unit. for speakers I have quality speakers nice 6x9 components and polk DB 4x6. basslink - all sounds good!!
but yeah i know what makes a sound system hum - mostly just wanted to see some door panel mods on 1st gen 2dr blazers..
Old Oct 31, 2013 | 02:02 AM
jvde's Avatar
same is not true for boss speakers, would never touch one of those. their head units tho - cool features. affordable. i say they are a pass if you want mobile video and bluetooth for less than $400
Old Oct 31, 2013 | 05:00 AM
dirt101's Avatar
Pyle actually makes great pro audio speakers. I should have known that was coming but those mids are definitely not bad. Considering I found them on one of twisteds videos.
Old Oct 31, 2013 | 07:54 PM
Blazin_Jason's Avatar
