94 Full Size Factory Stereo question...
Old Nov 1, 2009 | 07:40 PM
bestes's Avatar
bestes is an unknown quantity at this point
Default 94 Full Size Factory Stereo question...
I have a 1994 Full Size Blazer. When I purchased it, it had the factory stereo disconnected and a new stereo installed in the center of the dash. The factory stereo still remains in place, but unhooked. I was wondering if there was anyway to run power to the factory stereo so the clock will display. I only want to use the clock on the factory unit. Any tips would be appreciated.
I tried removing the factory stereo to take a look at the back, but I couldnt get it out. I did see a yellow and white wire and a group of wires taped together coming out the back.
Below is a picture of the factory stereo for reference. Thanks...
Old Nov 1, 2009 | 07:52 PM
*Moving to Audio/Visual* - The 1st Gen Tech section is for 1st gen s-series trucks. This thread seems to fit better in the Audio/Visual section.
I would say you just need to connect the ground, +12V constant, and switched ignition wires to the factory head unit.
Old Nov 1, 2009 | 09:14 PM
Blak92Blazer's Avatar
Blak92Blazer is on a distinguished road
SWART is correct.
youll need to pull the aftermarket stereo and splice the wires so you can power both units...
not sure how this will effect your stock fuses though... shouldnt be too much draw for the stock wiring if you leave the stock head unit off, and just have the clock displayed. worse case scenario dont turn both head units on at the same time.
your aftermarket unit will slide right out of the dash.. on the left and right sides there will be little release tabs, sometimes it takes a special tool but usually you can get to them with a couple small flat bladed screw drivers. youll have to depress the catches at the same time, and be able to pull the head unit out of the dash... sounds difficult but its not.
-Nate
Old Nov 1, 2009 | 10:32 PM
bestes's Avatar
Thanks for the help..
one more question..
What colors are the ground, 12v constant and ignition?
Thanks again...
Old Nov 2, 2009 | 08:14 PM
go through the audio video forum at the beginning theres a thread about this and it breaks down all the stock wiring for you....
admathi
Dec 15, 2019 04:24 PM
91s10blaze
May 1, 2012 05:15 PM
Kyle_Richard
Feb 24, 2012 05:12 PM
goerzenl
Nov 1, 2010 10:14 PM
The Beep
Feb 18, 2009 05:52 PM
