99 stock cd player
So I just picked up a 99 blazer a few weeks ago. The kid who I bought it from had an aftermarket cd player half assed in the stock location. No dash kit, just sitting in the hole. Well I went down to a local salvage yard and found a 2000 blazer with a factory delco cd player in it. I cut out the harness and brought the thing home. Wired everything up and nothing works. When I plug the unit in the cd player engauges but no display. If I hit the eject button I can hear it working but nothing happens. Also if I press the recall button the time will light up for about 5 seconds then shut off. The harness has 15 color coded wires and the only one I had an issue was the fact that in the harness there are 2 identical small green wires. Does this mean the unit is bad? Is there a way to repair them? I do not want an aftermarket cd player, I want a factory unit. Any help would be greatly appreciated.
Thanks!
Thanks!
My meter reads zero when touching the yellow wire with the ignition on. Im getting power into the unit but not through the switched yellow. What would be the cause of that?
I have power at the HU in the orange wire(constant) and I have power at the fuse block for both the orange and yellow wires on both sides of the fuses but nothing in the yellow switched wire at the back of the HU. Would this mean that its been cut by chance somewhere behind the dash? Im almost positive the PO had removed the dash for some reason. Would there be a fuseable link in that line by chance that I could check?
