99 stock cd player
Old Oct 31, 2010 | 09:32 PM
3day's Avatar
3day is on a distinguished road
In my harness I have 15 wires with only one of them being a true yellow. **EDIT**I have 3 dark green wires, one bigger gauge wire and 2 smaller ones. The green ones were the only ones im not sure of. As for the yellow wire I have voltage at the fuse block but not at the harness end. Yes I did swap in a fresh harness end. Im kinda stumped
**EDIT**
Old Oct 31, 2010 | 09:39 PM
zerepdivad's Avatar
zerepdivad is on a distinguished road
Battery
ORANGE
RADIO HARNESS
Accesory
DARK GREEN
RADIO HARNESS
Ground
BLACK
RADIO HARNESS
Illumination
GRAY
RADIO HARNESS
Dimmer
VIOLET/WHITE
RADIO HARNESS
LF Speaker (+)
TAN
LF Speaker (-)
GRAY
RF Speaker (+)
LIGHT GREEN
RF Speaker (-)
DARK GREEN
LR Speaker (+)
BROWN
LR Speaker (-)
YELLOW
RR Speaker (+)
DARK BLUE
RR Speaker (-)
LIGHT BLUE
That's your wiring. but if you really want you can clip off the yellow from where you have it hooked currently and hook it to the orange accessory wire in your ignition wiring. fuse it obviously. you should turn on from there. meter that "other yellow" and see to be 100% you didn't get them mixed up.
Old Oct 31, 2010 | 11:31 PM
3day's Avatar
Here is a pic of my new harness end. The harness in the blazer is identical. The yellow is the only actual yellow wire. There is one that would resemble a "dirty" yellow but every wire is color matched. Im about to tear my dash out and trace the wire from the fuse block to the harness end.
Question, if I take the yellow wire from the harness end and tie it into the orange constant wire so both wires will be constant to the HU, would it hurt anything?
Old Oct 31, 2010 | 11:39 PM
Smooth99LT's Avatar
Smooth99LT is on a distinguished road
I think your just dumb. roseburgians... they struggle a bit
Old Oct 31, 2010 | 11:41 PM
Smooth99LT's Avatar
Oh i forgot to tell you, i did get my stock stereo workin, turns out I did pop the lil 10A fuse in the inside panel. lower left corner. dangit
Old Oct 31, 2010 | 11:51 PM
3day's Avatar
brad your just jealous because I live in lost wages and you dont so suck it!
I have checked both fuses, both are still good. I just tried to tie the yellow and orange together on the harness end and connected them to the orange coming from the dash, still same scenario. Now my ****ty battery is dead so its on pause for now.
Old Nov 1, 2010 | 07:15 PM
zerepdivad's Avatar
From that picture i'm looking at that yellow that looks real yellow is your left rear speaker wire. i have a metra harness in front of me for a gm and that's waht it's pinned as from waht i can see.
the switched 12volts will be RIGHT NEXT TO THE CONSTANT 12v. exactly next to it.
Old Nov 1, 2010 | 08:28 PM
3day's Avatar
The wire directly next to the constant is a dark green wire. Also I color matched the wires. Would there be a difference because my blazer is a 99 and the HU is from a 00?
Old Nov 1, 2010 | 11:27 PM
zerepdivad's Avatar
Color wise there may be a difference. but pin location wouldn't change. since gm used this harness from like 88 til about 02ish. as a matter of fact i recall seeinga green switched wire from time to time. but whatever is next to your constant is definitely supposed to be your switched wire.
Old Nov 2, 2010 | 07:33 AM
3day's Avatar
When I get back I will try and swap some of the wires, thanks for your help!
