Adding secondary battery, is it safe to place inside the panels?
Old May 12, 2012 | 03:32 AM
SubbinBlazer's Avatar
SubbinBlazer is on a distinguished road
Default Adding secondary battery, is it safe to place inside the panels?
Hi, I was thinking of adding a secondary battery in the rear, but inside the panels. Is it safe? The type of battery I had in mind was an AGM battery bolted down in some sort of way. Not sure if there is even room inside the panels to fit a battery, but curious if anyone has popped the rear panels off and have an idea if a battery would fit back there somewhere. If I didn't need my cargo area, it wouldn't be a problem just throwing a battery in the cargo floor. Has anyone done what I have in mind or am I thinking the impossible for this vehicle? Thanks
Old May 15, 2012 | 07:10 PM
jagblazer01's Avatar
Your not going to fit a secondary battery behind any rear panel. There just isnt enough room.
Old May 15, 2012 | 08:39 PM
abig84's Avatar
if you do decide to just bolt it to the floor in the cargo area, they do sell battery boxes you can contain the battery in encase it leaks. having worked on limousines for many years they always find places to stick them, usually up in front fender kinda behind the bumper... have to fab a bracket but the connections always get crappy after a few years
Old May 16, 2012 | 03:37 PM
Would there be a significant difference if a secondary battery was placed under the hood rather then the rear?
Old May 16, 2012 | 08:30 PM
abig84's Avatar
it would be easier to wire up thats for sure. if you can somehow find room under there go for it. all my fullsized trucks ive had i ran dual batteries up front but there was plenty of room. could probably run like 6 if you wanted to
Jonas
Jul 19, 2012 10:02 PM
Diablo1982
Feb 27, 2011 07:38 AM
Spectreblazer
Feb 27, 2010 09:10 PM
94camaro
Performance & Brainstorming
15
Feb 6, 2009 07:22 PM
