After market head unit install 1998 2door
Old Jun 25, 2013 | 10:58 AM
ckroll98's Avatar
ckroll98 is on a distinguished road
Default After market head unit install 1998 2door
There is an after market head unit in my 1998 2door 4wd. I replaced the battery yesterday, but now the radio says "No Code" so do I need to have a code entered in the head unit?
Old Jun 25, 2013 | 03:51 PM
rexazz2's Avatar
check the glove box the code may be with the owners manual or a stop at your local dealership should be able to fix up the code for you
If you decide to go aftermarket Pretty much any aftermarket stereo head will work
You just need a harness kit and a dash kit with it
Your local auto supply should have them but here are some examples
Amazon.com: Stereo Wire Harness Chevy Blazer 98 99 00 01 (car radio wiring installation parts): Car Electronics Amazon.com: Stereo Wire Harness Chevy Blazer 98 99 00 01 (car radio wiring installation parts): Car Electronics
Amazon.com: Stereo Install Dash Kit Chevy Blazer 98 99 00 01 (car radio wiring installation parts): Car Electronics Amazon.com: Stereo Install Dash Kit Chevy Blazer 98 99 00 01 (car radio wiring installation parts): Car Electronics
Old Jun 25, 2013 | 04:02 PM
El_Beautor's Avatar
Are you sure that the radio is aftermarket? GM used a system called Theftlock where the user could enable a code to lock the radio to prevent theft. I believe there is a system to get the code for a GM radio, but you'll have to Google it. It may be easier to just get a new one.
If the radio is indeed aftermarket and employes a similar PIN type code, then unless the previous owner marked the code down somewhere you may be SOL. Like Rexazz said, check the owners manual and any related papers in the truck. Hopefully you'll be lucky and find it written down somewhere.
Old Jun 25, 2013 | 04:26 PM
ckroll98's Avatar
It's an aftermarket Kenwood already in the dash. I'll tinker with it tonight and look around for the code.
Old Jun 25, 2013 | 04:33 PM
rexazz2's Avatar
I misread
Thought it was the stock head
cant say I have seen an aftermarket that needs a pin in a long time
I thought everything was detachable face now
Old Jun 25, 2013 | 06:19 PM
El_Beautor's Avatar
I vaguely remember some old Kenwood decks had that "feature". Google the model number and PIN and see if you can find a way to reset it. Because it's an anti-theft "feature" I suspect that there isn't an easy way to reset it. You could try some generic pins like 0000 or 1234. Something like that.
Old Jun 26, 2013 | 08:47 AM
ckroll98's Avatar
Got it figured out. Had to use the remote to scroll through the source to get to the tuner.
SubbinBlazer
Apr 5, 2013 09:17 PM
JRob238
Feb 27, 2011 02:29 AM
if6was9
Mar 16, 2008 09:38 PM
nnnon632
Oct 22, 2007 01:34 PM
chevyrocksu
Headers, Intake, & Exhaust
Nov 25, 2006 03:29 PM
