Aftermarket CD Deck Install Troubles
Old Feb 8, 2011 | 07:53 PM
Radio_Flyer's Avatar
Radio_Flyer is on a distinguished road
Default Aftermarket CD Deck Install Troubles
Hi
I just purchased a Pioneer DEH 3200UD cd deck to replace the old tape deck that was in my 1st gen. Blazer(94). After connecting all the wires I was excited to start up the blazer and... Nothing. I have 0 power to the deck. So I went back through and checked all of my connections. I haven't done much as far as aftermarket audio installations and by no means would I say I really know a lot about it. After having a look at the old cassette deck I noticed there is no yellow batt. mem. wire. I was thinking maybe to check if there is any voltage coming from the batt mem wire from my blazer. That should be a constant power right? But even would that make a difference on why my deck isn't working? As far as I know it should be able to run off the red acc ignition wire no?
Any help would be greatly appreciated, Thanks.
Old Feb 8, 2011 | 09:00 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
From the first sticky in this forum:
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Old Feb 8, 2011 | 10:25 PM
I've already gone through all of that information before I posted. I'm 100% positive that I've hooked all the right wires up. I was looking for help as to where to start looking as to what my be the problem.
Old Feb 9, 2011 | 07:00 AM
Was the factory harness in place when you started or simply bare wires?
Old Feb 9, 2011 | 07:15 AM
cochran07's Avatar
cochran07 is an unknown quantity at this point
Check your fuses make sure you didn't blow it somehow as well.
Old Feb 9, 2011 | 10:28 PM
There was a harness in there. I believe it was from the cassette deck that was in there. It was not a stock deck.
Also I figured I may have to check my fuses, but I'm not sure on what's going on in there.
Old Feb 10, 2011 | 08:16 PM
Just in case anyone was following this, I don't have any power to my battery memory wire, which is why I didn't get any power to the deck. For now I just attached the Batt. mem. from the deck in with the igntion wire. And now I have power. It's gettin late where I'm at, so I don't think I will try get power to the batt. mem. until tomorrow. First things first, check my fuses....
Old Feb 10, 2011 | 09:31 PM
cochran07's Avatar
Yeah fuses are always the first thing to check. Let us know its hard to help with stereo stuff since we can't see it/trace it and we don't know if its been butchered up by the last owner.
Old Feb 10, 2011 | 11:03 PM
I got it going. Went out with a flashlight. It wasn't fuses, there was just no power to the battery memory. So after running some fresh wire and a little bit of struggling I have my new pioneer hooked up and pumping. I was actually really amazed at the sound coming from the speakers. It was as if I installed a whole new system.
Old Feb 11, 2011 | 06:03 AM
cochran07's Avatar
Well that's good to hear that you got it going.
swe007
Mar 23, 2011 11:13 PM
tonytime
Apr 16, 2010 02:31 PM
KB1990
Feb 16, 2010 01:35 PM
chuck28000
Sep 17, 2009 02:30 PM
schmatty
Feb 20, 2007 03:44 AM
