alpine mrp-m350 enough for...
Old Dec 5, 2007 | 05:36 PM
blazinloud's Avatar
Default RE: alpine mrp-m350 enough for...
was that a refurb.?
that is cheap, alpines amps are nice, but seem pretty expensive when compared to others.
dont get me wrong, I love my 501, but I payed almost $1 per watt retail. worth it? maybe.....if you really like fine tuning your system, the digi's were great.
Old Dec 5, 2007 | 06:04 PM
mdehoogh's Avatar
no it was new. i added all of the ebay auctionsthat werent "buy it now" to my watch list and watched and watched...
Old Dec 5, 2007 | 06:18 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
ORIGINAL: blazinloud
well now thats 450rms to a 500 rms sub.
Actually those amps are pretty underrated and actually pump out a good 1200RMS @ 2 or 4 ohms
Old Dec 5, 2007 | 06:47 PM
blazinloud's Avatar
I was talking about the mrp-m450.
and actually, its only rated for 400rms at 2 ohms.
and i wouldnt call an extra 200 watts pretty over rated.
my sundown will do over 2200rms at .35 ohms.....thats pretty underrated my friend.
Old Dec 5, 2007 | 09:36 PM
bobditts's Avatar
I think misunderstand the use of the term. I doubt your sundown amp was ever rated for anything at .35ohms. "rated" means that the company that makes the amp will do a certain power output at a certain impedence but is documented to actually put out more or less at that same impedence. In this case, at 2 or 4 ohms, the pdx 1.1000 is rated to pump out 1000RMS but in reality does about 1250RMS at 2 or 4 ohms (depending on the actual testing documented on the birth sheet). I highly doubt your sundown amp came with a birsheet that said "actual wattage - 2200RMS @ .35omhs".
Old Dec 5, 2007 | 10:54 PM
blazinloud's Avatar
*copy and pasted from Jacobs board*[/align][/align]results from the sundowns...
Test Vehicle.. mine.. 05 aveo..
RMS clamp and dmm, as seen in the 12" test session..
This testing includes recent results, and not so recent..
woofers used.. 2 Mags (1.9 dcr per coil), 2 FI Q 12's (1.4 dcr per coil)
either used 1 sub or both of the pair for loads..
pure 60hz sine was used to tested.. just under audible clipping
1 amp, single 1000ca everstart maxx, factory alt
4 ohm nominal = 518 watts @ 88% efficiency (voltage fell from 14.3v, to 14.0v)
2 ohm nominal = 948 watts @ 85% efficiency (voltage fell from 14.3v, to 13.6v)
1 ohm nominal = 1510 watts @ 78% efficiency (voltage fell from 14.3v, to 12.4 volts
.5 ohm nominal = 1615 watts @ 72% efficiency (voltage fell from 14.3v, to 11.8v)
.35 ohm nominal = 1748 watts @ 67% efficiency (voltage fell from 14.3v, to 11.4v)
amplifier was protection happy @ .35 with tones, and some music.
IMO.. one 1500d should be limited to 1 ohm nominal use in factory electrical systems.. for the sake of the car.. not the amp
now... to have fun with some juice..
1 amp, single 1000ca everstart maxx, 1 Eagle Picher 12a5000, factory alt
4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v)
2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v)
1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8 volts
.5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
.35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v)
amplifier did fine @ .35 with tones and music with the added battery
2 amps strapped, with both batteries (for the sake of not typing it over and over... voltage drops from 14.3v, to 12.8 the entire test... lol
4 ohm strapped = 1900 watts @ 82% efficiency
2 ohm strapped = 3150 watts @ 72% efficiency
1 ohm strapped = 3740 watts @ 68% efficiency
.5 ohm strapped = 4425 watts @ 65% efficiency
.35 ohm strapped = 5415 watts @ 62% efficiency
amps would only tolerate a VERY short burp @ .35.. [/align]
- Jacob Fuller
- Owner, Sundown Audio
- Associate, Stereo Integrity
[/align]not in the manual, or on the birth sheet. but this testing is from the man him self in a real world situation, just the way it should be imo.[/align][/align]5400 watts from a pair of 1500 watt amps aint too shabby imo[/align]
Old Dec 5, 2007 | 10:58 PM
mdehoogh's Avatar
i kinda thought underrated (in pretty much any context) meant: better than they say.
in the world of amps and woofers i take it to mean: more power than they say
idk
Old Dec 5, 2007 | 11:02 PM
blazinloud's Avatar
I guess you could look at it that way.....
But some companies over rate by 50 watts, others by.....alot more.
there are lots of variables when testing amps.
Old Dec 6, 2007 | 01:35 AM
AtreyuManiac's Avatar
AtreyuManiac is an unknown quantity at this point
So is the mrp-m450 enough?
cause theres one on ebay but it doesnt include a manual, 2 end caps, and hi-level input harness
what are all those...besides the manual
and can i get them easily for cheap?
if the amp is good enough then thats great.
im not looking to completely fine tune it as this is my first car and i plan to purchase a different one later on and then put all my time and effort into it
now im looking for something that will get the job done
and if its the 450 and the type r GREAT
Old Dec 6, 2007 | 11:13 AM
blazinloud's Avatar
they will work fine together. make sure you wire that amp at a 2 ohm load.
