RE: alpine mrp-m350 enough for...
ORIGINAL: otnietdehoooo i kinda thought underrated (in pretty much any context) meant: better than they say. in the world of amps and woofers i take it to mean: more power than they say ORIGINAL: blazinloud I guess you could look at it that way..... But some companies over rate by 50 watts, others by.....alot more. there are lots of variables when testing amps. ORIGINAL: AtreyuManiac So is the mrp-m450 enough? cause theres one on ebay but it doesnt include a manual, 2 end caps, and hi-level input harness what are all those...besides the manual and can i get them easily for cheap? if the amp is good enough then thats great. im not looking to completely fine tune it as this is my first car and i plan to purchase a different one later on and then put all my time and effort into it now im looking for something that will get the job done and if its the 450 and the type r GREAT the hi-level input harness is an optional line level converter built into the amp. If you dont plan on using RCAs to receive the signal, you must use the hi-level harness. If you plan on using RCAs, dont worry about it. The end caps are trim pieces to make the amp look prettier. Not necessary but helpfull. Not sure where you would buy them seperately. |
ummm, depends what voltage they're tested at too.......most are tested at 14.4.....some much lower.
my sundown is rated 1500@12.8volts all testing is not done the same. thats why they implemented the cea style. |
ORIGINAL: blazinloud ummm, depends what voltage they're tested at too.......most are tested at 14.4.....some much lower. my sundown is rated 1500@12.8volts all testing is not done the same. thats why they implemented the cea style. |
I ended up getting a brand new amp.....and it did not come with a birth sheet.
that is the man who designed, and built it, what other confirmation do you need? the results would still be very very close. and how would bench testing it be anymore accurate? thats as far from a real world situation then anything......do they compensate for box rise? dcr per coil, etc. the 3000d did 3200@1.33ohm@10.75volts. that was in house testing done at sundown audio done by the owner himself. and that was an ACTUAL ohm load. imo, sundown took an extra 3 steps when rating their amps. not to mention the 1500d can be ran all the way up to 17 or 18 volts, which also, is not in their ratings. |
