Alternator amperage
Old Nov 28, 2007 | 11:53 PM
dimmuborgir6nik6's Avatar
dimmuborgir6nik6 is an unknown quantity at this point
Default Alternator amperage
I have a 100 amp alternator. Now I know that's not a lot. I just put a system in my truck, upgraded my 60W head lights to 65W, and I bought 100W KC off-roading lights.
Is this too much to run on a 100 amp alternator?
In August my old battery leaked out and my truck died. When I had that battery my interior lights would always dim whenever I applied the brakes, opened or closed 1 window, when I turned my steering wheel and even when I turned my head lights on. So I had to change out that battery and the interiors stopped dimming for most things, but they still dim when I apply the brakes.
Will adding these new 100W lights be too much for a 100 amp alternator?
Old Nov 29, 2007 | 07:22 AM
jagblazer01's Avatar
Default RE: Alternator amperage
first thing to try....upgrade the "Big 3". if you still get dimming on bass hits then think about upgrading. What amp are you running with your system?
Old Nov 29, 2007 | 09:10 AM
hillbillyinOhio's Avatar
it sounds like you have a bad ground, if the lights are dimming by pressing the brake. Do what Jimmy (jab) said and at least upgrade the ground from batt to chassis and engine to chassis.
Old Nov 29, 2007 | 11:54 AM
I don't have an amp or sub yet. I couldn't afford that so I'm waiting that out. I was looking at some L7 subs and pretty powerful amps though.
Old Nov 29, 2007 | 11:56 AM
Yeah, with a low-end stock alternator I don't wanna put too much on it. Next thing I need is a dead battery.
captaincheesey
Jun 28, 2007 11:58 PM
blazinloud
Jun 18, 2006 06:53 PM
blazer1
Jul 25, 2005 05:04 PM
ThisSideUp
Jul 18, 2005 04:51 PM
shawnCRX
Jun 11, 2005 03:47 PM
