which amp
out of these do you think is the best???
Cerwin-Vega STEALTH1200.1 Monoblock Stealth 1200.1 Car Amp
Cerwin-Vega Stroker 1000 STKR1000.1 Monoblock Car Amplifier
Amazon.com: AUDIOPIPE APSM-1500 1500 Watt Mono Car Audio MINI Amplifier Amp APSM1500: Car Electronics
Hifonics BRX1200.1D Brutus 1200W RMS Class D Monoblock Amp (BRX-1200.1D)
Rockford Fosgate R1200-1D 1200W 1-Channel Class D Prime Amp
don't know how good there prime series is..
http://www.sonicelectronix.com/item_...TX-4200.1.html
Pioneer GM-D9601 1200W Max GM Digital Series Class D Monoblock Amplifier
ik its pioneer but its the champion series, so makes me wonder what kind of power it can really do.
may I recommend you take a look at the ct sounds amps. They have a 900, 1200, and 1400 all of which are rated at 12.8v so the 900 is comparable to the 1200ish watt amps you were looking at. The reason I would buy an amp from ct is there no questions asked 1yr warranty. Amps die quite often and a solid warranty that doesn't take years and doesn't require a million emails to convince the company it wasn't your fault is money well spent. This amp will outperform most amps you posted.
Ct Sounds 900 1D Amp Amplifier 900W RMS 2000W Max Class D 1 Ohm Stable | eBay
Trying to keep it around $200 maybe a little more. In all honesty the SQ1200 (soundqubed) and the Rockford r1200... I bought 2 sq hds212 d4 on black Friday. They're for my grand prix. IK Rockford is good but idk if there prime amps are?
hold on, you think ct sounds is mainstream in comparison to the sq1200? I don't care about mainstream vs not, but I would definitely say sq^3 is way bigger than ct. I would also recommend the sq1200 as well though. I have run a lot of their products and have two hdc3s in the blaze right now actually.
As I've mentioned before, in that price range, as long as it's from a reputable company you're just not going to see a real difference between any of them. The majority of them are all being built in the same buildhouses in Korea and China (mostly China) and the majority of them are using the same quality of parts. There's quite a few out there that share the same boards, etc. so there's not really any difference in those at all.
If you can swing a few extra more than the $200 then the Soundqubed, CT Sounds, Rockford, etc. should have just a small edge over the others you listed. If you just can't go over $200 the RE Audio, Hifonics and I'll add the PPI BK1300 are all great budget options for the price.
Have you considered buying used at all? You just might be able to find a Sundown 1k or 1200 from someone used for right about $200. Going used opens up the playing field on what you're able to get for your budget compared to new. Call up or email Sundown themselves and see what they have lying around. I got my SAZ-1500D used for $350 direct from Jacob and my used 125.2 for $150 (I think). If they've got a used 1k or 1200 I'm sure they could get you pretty close to $200 and that would be an uber solid amp to go with.
Don't over think it. For what you're doing it's not going to make an audible difference from one to the next as long as it's a decent brand.
